zazoos Posted April 1, 2006 Share Posted April 1, 2006 Accord 4cyl 5speed won't shift. 124,000 miles The clutch slave cylinder was going out, so I purhcased a new Clutch Master Cylinder, Slave Cylinder and the line from Honda. I installed them and the car ran fine for about a week. The cylinders are holding pressure and fully extending the clutch arm. Now the car doesn't want to go into any gear. If I turn the car off, I can change gears, when the car is running and in gear with the clutch pressed to the floor the car doesn't leach forward or give signs of the cylinders slipping. I suspect the clutch disc is worn and needs replacing. What is your opinion. Link to comment Share on other sites More sharing options...
Nancy Posted April 1, 2006 Share Posted April 1, 2006 Accord 4cyl 5speed won't shift. 124,000 miles The clutch slave cylinder was going out, so I purhcased a new Clutch Master Cylinder, Slave Cylinder and the line from Honda. I installed them and the car ran fine for about a week. The cylinders are holding pressure and fully extending the clutch arm. Now the car doesn't want to go into any gear. If I turn the car off, I can change gears, when the car is running and in gear with the clutch pressed to the floor the car doesn't leach forward or give signs of the cylinders slipping. I suspect the clutch disc is worn and needs replacing. What is your opinion. you should go to the introduction forum and introduce yourself first. i had a similar problem, i bled the clutch over again and it was fine. try that, if not, you might need a new clutch. at 124,000 miles, i wouldnt doubt it. Link to comment Share on other sites More sharing options...
Humphries Posted April 1, 2006 Share Posted April 1, 2006 i think the clutch needs replaced. my oem from the factory clutch is fine with 132k miles.. but its very likely its the clutch. Link to comment Share on other sites More sharing options...
zazoos Posted April 2, 2006 Author Share Posted April 2, 2006 Problem Fixed, I adjusted the part that screws onto the clutch master cylinder and attaches to the clutch pedal. I'm not for sure why the clutch worked the first week and then didn't but after adjusting the part and giving the clutch master cylinder more travel the car shifts fine. Thanks for the help. Zazoos Link to comment Share on other sites More sharing options...
cranny Posted April 2, 2006 Share Posted April 2, 2006 was gonna say theres only one way to tell you need a new clutch , when it slips , other than that its good to go. if its not engaging and disengaging than its not the clutch itself. Link to comment Share on other sites More sharing options...
WaNt An AcCoRd Posted April 4, 2006 Share Posted April 4, 2006 how can you tell when the clutch is slipping i think i burned my clutch doing burnouts Link to comment Share on other sites More sharing options...
cranny Posted April 6, 2006 Share Posted April 6, 2006 if you floor the car and it revs and doesnt accelerate than you know its slipping. Link to comment Share on other sites More sharing options...
94accordex Posted April 23, 2006 Share Posted April 23, 2006 i know just your problem step 1: go buy some dot 3 brake fluid step 2: unscrew grey cap closest to your drivers side fender near your windshield fill completely with brake fluid Step 3: pump your clutch 4 or 5 full times start car in neutral and shift into first have a nice day Link to comment Share on other sites More sharing options...
Humphries Posted April 23, 2006 Share Posted April 23, 2006 he already fixed it.. durrh Link to comment Share on other sites More sharing options...
