samcrac Posted April 12, 2006 Share Posted April 12, 2006 Hey, I wanted to put new speakers in the front 2 doors of my car. I know that the speaker size is 6.5" (please correct me if i am wrong). Does anyone happen to know what the max mounting depth of these speakers are? One set i looked at says 2.25" mounting depth (audiobahn as65q). Im not sure if these would fit or not? Also, is there anything i need to look for when changing out the back 6x9's to insure an easy fit. I dont wanna do alot of custom work, i would just like them to drop in! If anyone has any suggestions on speakers they have used, please tell me those too! Thanks for the help in advance Sam Link to comment Share on other sites More sharing options...
BimmerM3 Posted April 12, 2006 Share Posted April 12, 2006 I have Infinity Kappas in my '99, which are listed on the Infinity website as 2 3/16 mounting depth. When I first installed them, and the driver's window was lowered, the window would just barely scrape against the back of the speaker, so I put in a little plastic spacer that came with the speakers. That solved my problem just fine, but I'm not sure how big of a spacer you could fit in there. You might want to check that out before buying. Link to comment Share on other sites More sharing options...
