pageaccord Posted April 19, 2006 Share Posted April 19, 2006 hey there, my 99 accord has just started to blow only heat out the vents even when the temp control is all the way on cool or if i switch on a/c. checked fuses that seemed related and all looked ok. any ideas what's up and what to do?? thanks, page Link to comment Share on other sites More sharing options...
Attaus Posted April 19, 2006 Share Posted April 19, 2006 You might want to bring your car in to have a dealer look at it. The AC unit is probably the only thing I won't touch on my car (unless removing it) because of the freon. You might have a nicked line somewhere, or you just need to replace the freon. In any case, spend a few bucks and have it looked at. Link to comment Share on other sites More sharing options...
cranny Posted April 19, 2006 Share Posted April 19, 2006 needs to be charged with whatever they use now. used to be freeon Link to comment Share on other sites More sharing options...
Benji Posted April 19, 2006 Share Posted April 19, 2006 Does your Accord have climate control (V6 EX)? if not it could just be a connection between the Temp Control in the dash and the blend door in the HVAC box. if it does, i suppose it's possable that the climate control unit has gone "bad" though doesn't seem to be a common problem with Honda's it is for sure with Chryslers and GM's. I haven't seen a cable popping off on the 98-02 body style before, but I have on a '90. Just a thought, could be other things Link to comment Share on other sites More sharing options...
