jlh Posted April 19, 2006 Share Posted April 19, 2006 The check engine light is on in my 96 Accord. The diagnostic code that I read is 8 flashes, which is one of the following trouble codes: P1359-CKP/TDC Sensor Disconnect P1361-TDC Sensor Intermittent P1362-TDC Sensor no signal I have reset the check engine light and the same code comes in. I have measured the resistance of the CKP and TDC sensors and they are within spec. A week before the check engine light came on I had the car to the dealer for some warranty work that involved plugs, wires, new distributor cap, & new rotor. Is the dealer work a possible cause of the check engine light coming on? Any suggestions on what to do next? Link to comment Share on other sites More sharing options...
Benji Posted April 19, 2006 Share Posted April 19, 2006 dunno what those codes are but i do know that you can't "reset" the SRS light like you can the MIL (check engine light) I have been told that the easiest way to "reset" the SRS light is to unhook the battery both ends and let is set a min, then before hooking back up touch the + and - ends togeather. worth a shot, I still need to try it with mine, it's been on since i swapped the front seats (side airbags were unhooked for a min) good luck Link to comment Share on other sites More sharing options...
