jeremy78951 Posted April 23, 2006 Share Posted April 23, 2006 I just picked up a 91 accord ex and the brakes were great when i test drove it.But on the way home i slowly applied the brakes and the petal slowly went to the floor.Next stop they worked great.In short they work great most of the time pedal right at the top but every once and awhile the pedal will go right to the floor they don't leak i am not losing fluid anywhere does this sound like a mastercylinder to you guys?I am not sure if they are antilock i dont see a abs light anywere.Thanks for any help Link to comment Share on other sites More sharing options...
90IntegraC1 Posted April 23, 2006 Share Posted April 23, 2006 air in hydraulic lines, master cylander needs to be replaced, no brake fluid in master cylander, loose or damaged brake lines those are a few things that could be the problem Link to comment Share on other sites More sharing options...
Attaus Posted April 23, 2006 Share Posted April 23, 2006 I experience the same thing.. check the lines first, but most likely you'll need to replace the master cylinder. $150 + labor.. have fun, and yell at the people who sold you the car. Link to comment Share on other sites More sharing options...
Bigdadybiggs Posted April 23, 2006 Share Posted April 23, 2006 Its probably from leaving the e-brake on cuz the same thing happend in my old saturn Link to comment Share on other sites More sharing options...
drunk engine Posted April 27, 2006 Share Posted April 27, 2006 sounds like the brake fluid is bypassing the the pistons in the master cylinder, and then re-entering the reservoir when you apply pedal. this is a common problem of a bad master cylinder. verify it with a mechanic, but i would say its a bad master. Link to comment Share on other sites More sharing options...
