deimos_031206 Posted April 24, 2006 Share Posted April 24, 2006 i have a 94 accord ex, due to complications i am converting the ABS to conventional what i need to know is what proportioning valve can i use? what is the interchaneability between the years? any know how would help..... also i need the rear calipers and mounting brackets....i posted up in classifieds but i need this stuff soon as the car is not being able to stop so well without them.....(dont ask why there not there, long story) Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted April 24, 2006 Share Posted April 24, 2006 if your brakes arnt working due to abs, pull your abs fuse out and they will act as conventional brakes although it will not pass inspection like that Link to comment Share on other sites More sharing options...
Benji Posted April 24, 2006 Share Posted April 24, 2006 Would be cheaper and easier to replace the complete ABS unit with a used one...you could get one for under $150 bucks... Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted April 24, 2006 Share Posted April 24, 2006 or you can pull the fuse and cut it out the abs system for about 25-30 secs of your time Link to comment Share on other sites More sharing options...
Benji Posted April 24, 2006 Share Posted April 24, 2006 or you can pull the fuse and cut it out the abs system for about 25-30 secs of your time will the idiot light go out after the fuse is pulled? Link to comment Share on other sites More sharing options...
deimos_031206 Posted April 24, 2006 Author Share Posted April 24, 2006 um......i already have pulled out the entire abs system, i have already installed the new non-abs master and the new lines. what i need to know is what proportioning valve can i use from what year car? also does anybody have these parts rear calipers and brackets all the rubber hoses for the rear brakes (both sides) thanx Mike Link to comment Share on other sites More sharing options...
Benji Posted April 24, 2006 Share Posted April 24, 2006 hmm, prop valve not showing up in Repairmate.. but I can tell you that the rear calipers are the same from '94-'97 (non wagon) so you should at least be safe in that range. and no I/we have none Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted April 24, 2006 Share Posted April 24, 2006 any thing in your generation accord should pretty much work, check napa, remember in most states if you convert to non-abs your vehicle will not pass inspection, Link to comment Share on other sites More sharing options...
deimos_031206 Posted April 25, 2006 Author Share Posted April 25, 2006 i live in tampa florida, we have no inspections......as far as the proportioning valve goes would one from a prelude 92-95 work? Link to comment Share on other sites More sharing options...
