sohcVTEC-E Posted April 27, 2006 Share Posted April 27, 2006 Should I buy Royal Purp. Ice? Would it really keep my engine a lot cooler? Or should I spend the 14 dollars on something else? Link to comment Share on other sites More sharing options...
90IntegraC1 Posted April 27, 2006 Share Posted April 27, 2006 motor oil is motor oil. buy mobil 1 synthetic for $4 Link to comment Share on other sites More sharing options...
Benji Posted April 27, 2006 Share Posted April 27, 2006 what's wrong with the factory coolant? If your looking to have your engine run cooler check into a different thermostate first. Link to comment Share on other sites More sharing options...
Benji Posted April 27, 2006 Share Posted April 27, 2006 motor oil is motor oil. buy mobil 1 synthetic for $4 true oil is oil, what makes them all different is the additives. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted April 27, 2006 Author Share Posted April 27, 2006 It's a coolant additive. I was just wondering if I would be wasting my money by getting it. Link to comment Share on other sites More sharing options...
Benji Posted April 27, 2006 Share Posted April 27, 2006 yes, save your $$ Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 27, 2006 Share Posted April 27, 2006 I use it. Just for the hell of it . Link to comment Share on other sites More sharing options...
TS John Posted April 28, 2006 Share Posted April 28, 2006 People started talking about motor oil because Royal Purple makes oil. I don't think 90IntegraC1 had ever heard of Royal Purple Ice, so he just assumed it was the oil he had heard about. I totally agree with how infuriating it is to hear that "oil is oil." That's like the people that would come into the tire shop and say that "a tire is a tire." If there weren't any differences between products, I think people would have caught on by now. About what you said about the flaws of synthetic oil, would that especially be a problem with high mileage engines? My car's got a lot of miles on it, and an oil change coming up and I was thinking of going full synthetic with it. Is that something you would recommend, or should I stay with regular oil or semi-synthetics for high-mile vehicles? Link to comment Share on other sites More sharing options...
CleanGSR Posted April 28, 2006 Share Posted April 28, 2006 To be quite honest, most of the additive "packages" that good synthetic oils use eliminates the problem. I know that Mobil1 uses PAO's and garuntees not to effect the seals. Royal Purple has the same garuntee, but nowhere on there site do they tell what synthetic basestock they use. That personally bothers me. I've been doing some research on synthetic oils today and have found a lot of good things about AMS synthetic, German Castrol Syntec 0w30, and Redline. My research continues. Link to comment Share on other sites More sharing options...
TS John Posted April 28, 2006 Share Posted April 28, 2006 Cool. I like Mobile 1 a lot. I think that's the direction I'm gonna go in, unless you can come up with some compelling reasons otherwise... Link to comment Share on other sites More sharing options...
CleanGSR Posted April 28, 2006 Share Posted April 28, 2006 I run Mobil1 Synthetic now, but will possibly switch. It looks like Mobil1 is a great oil, but there might be some slightly better. In reality it probably doesn't make much difference since they will both be high quality, but we'll see. IMO, if you are going to run synthetic oil, you should pick a manufacturer and stick with them. You don't want to switch between the characteristics of shrinking seals PAO's and swelling seals Diesters. I don't think either one shirnks or swells enough to make it leak, but going back and forth between them might make that happen. Link to comment Share on other sites More sharing options...
CleanGSR Posted April 28, 2006 Share Posted April 28, 2006 I'm leaning heavily toward AMSOIL's Synthetic oil. Every single place I research goes back to saying that their oil protects leaps and bounds better than the next closest competitor. The same research shows Royal purple and Redline pretty far down on the list as far as protection. Also redline is the only company so far that I've seen that uses Polyolesters instead of PAO's. Don't know if that's good or bad, but interesting nonetheless. Link to comment Share on other sites More sharing options...
TS John Posted April 28, 2006 Share Posted April 28, 2006 AMSOIL? I think I've seen that around. If it isn't too much more than Mobile 1 then I'll give it a yoink. Right now I've got Pennzoil semi-synthetic high-mileage vehicle oil in my car and it runs perdy well. Still, if I can upgrade, why not? Link to comment Share on other sites More sharing options...
CleanGSR Posted April 28, 2006 Share Posted April 28, 2006 AMSOIL will cost a decent bit more than Mobil1. Closer to the pricing of Royal Purple. I just got done reading a fairly large write-up by a Triboligist regarding the motor oil. I'm not going to get into all his details, but after reading his writeup I will be using AMSOIL S2000 oil or Redline oil from now on. He referenced Royal Purple in saying that they would not give him any information about their product for him to analyze, which made him very skeptical. Every other company he talked with, gladly gave the stuff he wanted for analyzation. Link to comment Share on other sites More sharing options...
TS John Posted April 28, 2006 Share Posted April 28, 2006 Sounds like you really did your homelywork on this one. Thanks for the advice. AMSOIL or Redline it is! Link to comment Share on other sites More sharing options...
CleanGSR Posted April 28, 2006 Share Posted April 28, 2006 If you have a minute go to AMSOIL's website and read up some of their stuff. They had a guy with a MACK truck that went 409,000 miles on an oil change and then had the engine torn down and analyzed. The engine didn't have anymore wear than if it had been changed every 20,000 miles (like manuf. suggested on that truck). Link to comment Share on other sites More sharing options...
TS John Posted April 28, 2006 Share Posted April 28, 2006 Cool, I will try to check that out. I figure I should go to this meeting now, since I've done enough post whoring today and I'm already five minutes late. Link to comment Share on other sites More sharing options...
SolLesHonda Posted April 28, 2006 Share Posted April 28, 2006 I looked at some of that, but think I am still going to stay with the Royal Purple I have been using. It seems great and have great experiences lately. Great info nevertheless. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted April 28, 2006 Author Share Posted April 28, 2006 Same, after I put royal purple in my car, she stopped burning oil. That is until VTEC hit but I hear most cars with VTEC do burn oil when it kicks in. True or false? Link to comment Share on other sites More sharing options...
TS John Posted April 29, 2006 Share Posted April 29, 2006 I'd never heard that before, but that doesn't mean it's not true. I would tend to doubt it, though, since I don't see honda engineers designing technology that commonly burns oil. Link to comment Share on other sites More sharing options...
Idon'tknow Posted April 29, 2006 Share Posted April 29, 2006 So where did Mobil 1 fall on the list of oils you've checked into. I've been using it for quite some time and don't want to switch with out a good reason. I like sticking with one brand due to additive pkgs. Link to comment Share on other sites More sharing options...
