honda16 Posted April 29, 2006 Share Posted April 29, 2006 My cousin has a flat now and cannot take the tire off. She took off all the bolts but the tire still wont come off. her mom took the car last week to get new tires and the man told her she has locked tires. But he told her some way to take it off but she cant remember. does anyone know? P.s they just bought the car. Link to comment Share on other sites More sharing options...
stetypeR Posted April 29, 2006 Share Posted April 29, 2006 When you say tire do you mean wheel?? if she has taken off all the bolts including any locking wheel nut and the wheel is still tight on, then try hitting the tire to make it loose if its still tight then try hitting the rim from behind with a rubber mallet, if possible when you have had a new tire fitted put some copper grease on the hub and a bit on each bolt that should stop it siezing next time it needs to be removed. Link to comment Share on other sites More sharing options...
honda16 Posted April 29, 2006 Author Share Posted April 29, 2006 When you say tire do you mean wheel?? if she has taken off all the bolts including any locking wheel nut and the wheel is still tight on, then try hitting the tire to make it loose if its still tight then try hitting the rim from behind with a rubber mallet, if possible when you have had a new tire fitted put some copper grease on the hub and a bit on each bolt that should stop it siezing next time it needs to be removed. i think thats it the wheel lock nut. She cant find it. do you kno where it is? Link to comment Share on other sites More sharing options...
