sohcVTEC-E Posted May 13, 2006 Share Posted May 13, 2006 Okay, I put 2 quarts of GM synchromesh in like SolLes and SSR suggested. It helped a lot, I feel like I'm shifting through butter. However, the first-second synchro is REALLY loud now and when I take my foot off clutch in neutral the input shaft spins a lot louder too. When I had the Honda MTF in there it was barely audible... There is also sometimes a clunking sound when my foot is off the clutch in neutral. Yesterday I was scared of these noises so I put like another half of a quart in. Whats going on? Should I drain the extra out and just get used to the noises or is something else going on? Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 13, 2006 Share Posted May 13, 2006 Hmm, mine made 0 noises. I say drain out the extra, and see if it keeps doing it. Give it a little bit, and if it still does it, then let me know. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 13, 2006 Author Share Posted May 13, 2006 Wurd, thanks man. Link to comment Share on other sites More sharing options...
Chubs Posted May 13, 2006 Share Posted May 13, 2006 Are we talking about trans fluid here ? Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 13, 2006 Author Share Posted May 13, 2006 Yeah. GM Synchromesh transmission fluid. Link to comment Share on other sites More sharing options...
cranny Posted May 14, 2006 Share Posted May 14, 2006 well since the cars not a GM i have no clue why youd have that in there nor do i understand why someone would recommend it. take that crap out and put either hondas MTF in it(best) , or 10W30 motor oil in it. now. do you need someone to tell you that when it was quiet before and since putting it in its not , that thats a bad thing? Link to comment Share on other sites More sharing options...
..SSR.. Posted May 14, 2006 Share Posted May 14, 2006 Ok, sorry. cranny, STFU. I build engines and transmissions for a living. GMSM works wonders. gunit, the clunking noise is your input shaft bearing, it is going bad. Don't drive hard on it. If it explodes, kiss your transmission goodbye. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 14, 2006 Share Posted May 14, 2006 Cranny, seriously, I recommended it and so did ..SSR.. It really does work. I use it. Maybe you should. Mr. Doubtful. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 14, 2006 Author Share Posted May 14, 2006 Didn't the clutch kit come with a new shaft bearing? Link to comment Share on other sites More sharing options...
..SSR.. Posted May 14, 2006 Share Posted May 14, 2006 No. You would have had to split the transmission open and pulled the shafts out. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 14, 2006 Author Share Posted May 14, 2006 f*ck!!!!!!!!!!!!!!!!!! Well I guess its a good thing I'm getting a new trans from you soon. Lol. About that: sorry I have yet to send you a down payment. Some flake-o is taking forever to pay me for some crap I sold him on Ebay. Once he gives me the money, 50 bucks is headed your way. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 14, 2006 Share Posted May 14, 2006 We're going to change yours up a bit. Z6 trans ZC 3rd 96-00 DX 3rd gear for 4th gear ZC 5th gear Z6 final drive Red is the hybrid trans http://www.fatboyraceworks.com/gears/index...Graph&Compare=1 Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 14, 2006 Author Share Posted May 14, 2006 I have 14 inch rims. I noticed that said 15's. What is my cruising RPM gunna be at 70 in fifth? Will it still cost around $500? Do you think an Action flywheel would be cheaper? Or should we stick with the Fidanza? Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 14, 2006 Share Posted May 14, 2006 I want a new Findal Drive damnit. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 14, 2006 Author Share Posted May 14, 2006 THEN GET ONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
cranny Posted May 14, 2006 Share Posted May 14, 2006 hilarious. i build engines and trannies too goofy(repair mostly or change) , since you were in diapers. and if the man says it started makin noise after he put it in , well i guess its the bomb sorry my bad. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 15, 2006 Share Posted May 15, 2006 I have it in mine. My tranny is in damn near perfect condition. Link to comment Share on other sites More sharing options...
cranny Posted May 15, 2006 Share Posted May 15, 2006 power to yas and no offense meant. just why fix it if it aint broken. the tranny is designed to run a certain kind of fluid , why stray from it when it does nothing for you is all im sayin. maybe his car had a bearing on the edge of wearing out. and maybe that fluid pushed it over the edge cause it does not work as well as what the car was designed for. i tell ya another reason i wouldnt use it , and this is personal with GM , GM makes garbage quality cars period. from cavaliers to cobalts to corvettes. all junk in my eyes. ive seen countless number of chevs over the last 15 years pack it in way before thier time. i drove a brand new Z06 not 2 weeks ago with 5 miles on it , clunky shifting , tight cockpit , deathtrap. my point being is they make second rate vehicles. so would i use any product GM has designed or manufactured? thats a big negative. hmm what would i do if i were GM , well first off i wouldnt make 18 diffferent cars and put the SAME DAM MOTOR IN EVERY ONE!! good thing for a 350 small block or theyd a gone outa business in the 70's. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 15, 2006 Share Posted May 15, 2006 The trans wasn't designed for a certain kind of fluid. Fluid is fluid. GM just has the good stuff. Link to comment Share on other sites More sharing options...
civic_crazy91 Posted June 3, 2006 Share Posted June 3, 2006 Mine did the same in my 91 hatch. i opened it up and saw that the main shaft bearing were chewed to crap. i replaced them along with the main shaft seals and axle seals and it is like a new tranny now. so it might be the MAIN SHAFT BEARINGS there are two. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted June 3, 2006 Author Share Posted June 3, 2006 Oh its fine now... This thread was dead. Link to comment Share on other sites More sharing options...
Kastigir Posted June 3, 2006 Share Posted June 3, 2006 For the record, Honda Certified mechanics recommend GM Synchromesh if you're having tranny problems. Link to comment Share on other sites More sharing options...
