crazycrak Posted June 5, 2006 Share Posted June 5, 2006 OK I have 87 Accord The clutch is stiff and feels good to about an inch away from the floor going down when it gets to a spot it falls to the floor it gets easy...then letting it out ... on the way back up the same amount is really soft like theres nothing there then u get past it. it feels like a kick and the pedal comes up quick Is this normal for a cable clutch r whats wrong Link to comment Share on other sites More sharing options...
cranny Posted June 5, 2006 Share Posted June 5, 2006 normal. as long as your clutch aint slippin its prolly ok. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted June 6, 2006 Share Posted June 6, 2006 i am not as sure as cranny here but check ur pedal spring it could be cought or some thing. Link to comment Share on other sites More sharing options...
cranny Posted June 7, 2006 Share Posted June 7, 2006 your clutch should have 3/4 of an inch of freeplay in the cable. in other words no tension on the clutch cable when clutch is disengaged as it doesnt fully release and wears it out. too much freeplay and the clutch doesnt disengage fully when pedal is depressed. usually your pedal should start to grab about halfway out from the floor. like i said make sure theres 3/4 of an inch freeplay. Link to comment Share on other sites More sharing options...
