cemorris Posted July 28, 2006 Share Posted July 28, 2006 It is an ex 4 cylinder with automatic tranny and 75,000 miles. I beleive it is leaking from the driver side axle seal. I replaced the seal about a month ago, but it seems it is still leaking. I went under it this morning to try and determine if I mis-diagnosed the leak. I am 75% sure it is still coming from the axle seal. There is a lot of oil built up around the point where the shift cable enters the tranny. I am fairly confident that it is oil that has just dripped down from the axle seal however. My question is that is it possible I got a defective new seal? I was pretty carfull when re-installing the axle. Could it be the axle it self? Just looking for opinons on what I should do next. Any thoughts? Could I have messed up the repair and need to do it again? Link to comment Share on other sites More sharing options...
Kastigir Posted July 28, 2006 Share Posted July 28, 2006 Yes, not likely, and yes. Link to comment Share on other sites More sharing options...
cranny Posted July 28, 2006 Share Posted July 28, 2006 does the axle snap in? if it doesnt click than somin else is wrong. is it tight to trans? i doubt you have a bad new seal , id bank more on mis-installation. Link to comment Share on other sites More sharing options...
