RODNEYCHAN Posted August 3, 2006 Share Posted August 3, 2006 Hi, I would like some suggestion.. I m seeking coil over to lowering my 05's Accord V6 MT coupe, and which brand or model should I pick. I m looking to have comfort and little more handling at the same time. I m looking at Tein Super Street Damper, anyone know is it good, and how is the comfort about that...? Or any suggestion?? Thanks Link to comment Share on other sites More sharing options...
TLontheDL Posted August 3, 2006 Share Posted August 3, 2006 Tein is pretty comfortable. If you are really seeking a stock like ride, you can't go wrong with b+g, tein or the high end brands. There are ground control and skunk2 but they're really rough unless you get aftermarket shocks that are compatable with it. Link to comment Share on other sites More sharing options...
RODNEYCHAN Posted August 3, 2006 Author Share Posted August 3, 2006 THANKS FOR YOUR SUGGESTION FOR EXAMPLE IF I GETTING THE EIBACH PROKIT OR THE SPORTLINE, AND GO WITH THE KONI OR TOKICO DAMPER, WILL IT BE BETTER THAN THE TEIN SUPER STREET? AND ALSO FOR TEIN SHOULD I JUST GET THE TEIN BASIC OR SS-P? WHICH ONE WILL GET MORE COMFORT.. ? THANKS AGAIN Link to comment Share on other sites More sharing options...
RODNEYCHAN Posted August 3, 2006 Author Share Posted August 3, 2006 ALSO ANYONE KNOW DO I NEED TO CHANGE THE CAMBER AS WELL.. IF YES WHAT BRAND SHOULD I GET.. Link to comment Share on other sites More sharing options...
accord313 Posted August 4, 2006 Share Posted August 4, 2006 whenever you lower your car you'll need to change the camber so you'll have to find a camber kit for the front and rear..im not sure on what kind to use bc i just used an offname brand when i did mine Link to comment Share on other sites More sharing options...
90IntegraC1 Posted August 4, 2006 Share Posted August 4, 2006 my friends that have used a matched spring and shock set have more comfortable rides then coilovers or just lowering springs... go with the eibach springs b/c that ride is good and tokico or koni struts Link to comment Share on other sites More sharing options...
