Mike 2006 Accord EX-L V6 MT Posted August 14, 2006 Share Posted August 14, 2006 Is anyone familiar with the process of adding an amplifier to a 2006 Accord EX w/ XM (I want XM to still work) Some questions: 1. Does the factory stereo have pre-amp outputs to hook up an amplifier via RCA cables? 2. If no to the first question, how would an amp be added to the factory head unit, and what are the pros/cons? -Mike Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted August 14, 2006 Share Posted August 14, 2006 If tnot, there is an adadpter thing thats spliced into the speker wires, I jsut did this the other day, same as havings rca outsput. Link to comment Share on other sites More sharing options...
cranny Posted August 15, 2006 Share Posted August 15, 2006 its called a line level adaptor. has a crossover built into it too. there not that spensive either. it turns speaker wires , into RCA's if you follow me , lol. PS. wont disturb Xm. Link to comment Share on other sites More sharing options...
That Guy Posted August 15, 2006 Share Posted August 15, 2006 try to find the adaptors that you can adjust the amp level on though. i made the mistake of buying ones that didnt have an adjustment on them and i had to adjust it through the deck waaaay too much. plus the ones with adjustments on them sound better. Link to comment Share on other sites More sharing options...
cranny Posted August 15, 2006 Share Posted August 15, 2006 amp levels can be adjusted on the amp with the gain control and fine tuned with head unit. line level adaptor will only have one thing built into it , a crossover. a dial that will allow you to only send what frequencies you want to the speaker if you follow me. Link to comment Share on other sites More sharing options...
