99OmaAccord Posted August 15, 2006 Share Posted August 15, 2006 I was wondering if anyone knows how to install Halo Headlights on a 99 Accord...Im not quite sure on what i have to do to install them to get them to work....especially those two wires that come off of the halo...anyway just hit me up if you have any suggestions Link to comment Share on other sites More sharing options...
b16bhonda Posted August 16, 2006 Share Posted August 16, 2006 there's a couple ways to do it...i'll tell you the way i hooked up mine. i went to the parts store and bought a simple switch (has 3 connectors on the back...one for power, one for ground, and one for the accessory or your lights) then you run a wire from the positive battery terminal to the (+) connector on the switch. then you run a wire from the (-) connector on the switch to a grounding spot somewhere. -now the switch is hooked up and ready for an accessory...or, in this case, your halo's then connect all the red wires coming from the halo's...and run a wire from these to the (acc.) part of the switch. then connect all the black wires coming from the halo's to a grounding spot. flip the switch and... this way, the key doesn't have to be in for them to work, you can just flip the switch whenever you want them to come on, since they have constant battery power. Link to comment Share on other sites More sharing options...
Brian3311 Posted August 16, 2006 Share Posted August 16, 2006 whats the best way to connect the wire to the battery? My friend did it with electircal tape but that seems like such a nigrig and i was wondering if there is a better way Link to comment Share on other sites More sharing options...
b16bhonda Posted August 16, 2006 Share Posted August 16, 2006 take the terminal ring off the battery and slide it back on with the wire along the side so it's tight in there Link to comment Share on other sites More sharing options...
b16bhonda Posted August 16, 2006 Share Posted August 16, 2006 let us know how it goes...installation, operation, etc. Link to comment Share on other sites More sharing options...
