dron Posted August 27, 2006 Share Posted August 27, 2006 Should the DRL indicator (big yellow "DRL" letters on dashboard) light up when the igniton is turned on or does it only light up when there is a problem with the DRL system? Manual is quite contravercial on that one. But Quick Start Guide says literally following:"DRL indicator: Comes on when you turn the ignition to ON(II) with the headlight switch off and parking brake set..." However, on my brand new Honda Accord EX-L this indicator never comes on... Thanks, Link to comment Share on other sites More sharing options...
