helpmeplz Posted September 4, 2006 Share Posted September 4, 2006 these was in my car when i got em but theres a switch that goes to em to change the colors but it stays white and dotn light up behind the gauges light up over them can someone tell me how the fk u get the dash piece off lol i took all the screws out but crap still feels like its bolted down and it not tryin to come out its in a 93 accord 5 speed thx Link to comment Share on other sites More sharing options...
alias Posted September 4, 2006 Share Posted September 4, 2006 on the civics, there is a trim piece that you must remove first. it has 2 screws in it and goes all the way around the gauge cluster. probably the same on accords. if you've already removed these, then there should be 4 more screws holding the cluster in place. look into getting a haynes manual for your car, they're very helpful with giving detailed directions on how to take yur car apart Link to comment Share on other sites More sharing options...
helpmeplz Posted September 4, 2006 Author Share Posted September 4, 2006 i got all the screw out but it still feels like there is more but there isnt ive looked i got it half way off but around the radio its like its stuck Link to comment Share on other sites More sharing options...
alias Posted September 4, 2006 Share Posted September 4, 2006 woah, nevermind...i totally thought you meant the instrument gauges. you gotta start using some punctuation man lol...sorry i couldn't help. like i said, go to autozone or something and pick up a haynes manual. it will help tremendously Link to comment Share on other sites More sharing options...
helpmeplz Posted September 4, 2006 Author Share Posted September 4, 2006 lol thats what im talkin about the speedo and rpm gauges Link to comment Share on other sites More sharing options...
alias Posted September 4, 2006 Share Posted September 4, 2006 with my civic cluster, i just removed the screws and yanket it out...i think in addition to the screws there were two clips on the bottom holding it on. look for clips. or get a haynes manual FTW Link to comment Share on other sites More sharing options...
helpmeplz Posted September 4, 2006 Author Share Posted September 4, 2006 ok i found my problem the box that goes to the gauges for them 2 light up has melted and doesnt work n e more were can i find the box ??????? Link to comment Share on other sites More sharing options...
b16bhonda Posted September 5, 2006 Share Posted September 5, 2006 those gauge faces will have to come out, unless you can find the exact relay box that goes with it...in which case you would be better off to just get a new set of gauge faces. just go the easy way for now and find a way to get that cluster out. then you can take the plastic cover off and unscrew the faces. Link to comment Share on other sites More sharing options...
helpmeplz Posted September 6, 2006 Author Share Posted September 6, 2006 na i need the box that goes to the plugs on the gauges that makes the light work called power inverter 4 2 colors i got em out Link to comment Share on other sites More sharing options...
b16bhonda Posted September 6, 2006 Share Posted September 6, 2006 if we're thinking about the same thing, i don't think you can just buy those separately. you would need to get a new gauge face set. and if you found one, it would have to be the same as the one you have now...for different colors. that's gonna be hard to find, that's why i said it would just be easier to get new faces if that's what you want. i'd leave the gauges stock...they look nicer imo Link to comment Share on other sites More sharing options...
