gagirl4 Posted September 11, 2006 Share Posted September 11, 2006 Has anyone replaced the camshaft position sensor on an 03 Accord EX 4 cyl.? If so, where is it located? How do you replace it? Link to comment Share on other sites More sharing options...
macdragin Posted October 25, 2006 Share Posted October 25, 2006 Has anyone replaced the camshaft position sensor on an03 Accord EX 4 cyl.? If so, where is it located? How do you replace it? CMP Sensor A Replacement 1. Remove the air cleaner. 2. Remove the EGR valve. 3. Disconnect the CMP sensor A connector (A). 4. Remove the bolt (B). 5. Remove CMP sensor A © from the intake camshaft side of the cylinder head. 6. Install the sensor in the reverse order of removal with a new O-ring (D). Link to comment Share on other sites More sharing options...
