milkissolid Posted September 25, 2006 Share Posted September 25, 2006 my radiator is busted, is it easy to change? Or do you know how much it would cost for a garge to change it. I have a 2.2i N reg LS any words of wisdom would be really helpful. Link to comment Share on other sites More sharing options...
mycarsux Posted September 25, 2006 Share Posted September 25, 2006 radiator changes by a mechanic are actually kinda expensive. what year is your car? like middle or late 90's? i'm not sure how hard it is. depends how much experience you have with an engine. like i have practically none so it would be kind of difficult for me. if you need the car on short notice and you have no experience, go to the mechanic :( if you need the car on short notice but you think you can do it, pick up a manual from pepboys, a radiator, new hoses, etc. and go for it. Link to comment Share on other sites More sharing options...
Jeffro Posted September 25, 2006 Share Posted September 25, 2006 A buddy and I changed the radiator on my wife's old civic one time, and we were estimating about 2 hours to do it, and it turned out about 45 minutes did it from beginning to end. Here's what I rememberL Drain coolant... loosen about 4 bolts and hoses and lift out old radiator... As a Haynes manual would state, "intallation is the reverse of removal." Never had to do it on my Accord, but it is much easier than the dodge vehicles I've seen it done on where you have to remove the entire front end just to get to it. If you can get a hold of a Haynes or someone on here can give you a specific DIY, I'd recommend that before you take it to a shop... You only have to be a little mechanically savy to figure it out I believe! Link to comment Share on other sites More sharing options...
airjordan223 Posted September 25, 2006 Share Posted September 25, 2006 yeah ive changed one out before, its basically what ^ he said. drain the coolant, loosen some bolts, take it out, put the new one in, bolt it on, and add coolant. the hardest part i remember was taking off some of the hose clamps, but that was just getting the right angle. i think you can diy Link to comment Share on other sites More sharing options...
mycarsux Posted September 25, 2006 Share Posted September 25, 2006 yeah it is REALLY expensive if you have a mechanic do it. i think i paid $1200 for a job once Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted September 25, 2006 Share Posted September 25, 2006 Its easy, took me about 10-15 minutes in my sol. Link to comment Share on other sites More sharing options...
milkissolid Posted September 26, 2006 Author Share Posted September 26, 2006 Thanks for all you words, i think i will give it a go at the weekend. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 26, 2006 Share Posted September 26, 2006 Radiator took me 20 minutes in my sol. Link to comment Share on other sites More sharing options...
TLontheDL Posted September 26, 2006 Share Posted September 26, 2006 i busted my radiator while driving and smoke was coming from the hood once. i had to get it towed. the cost of towing, new parts, and labor came out to be like 400 bucks. :( Then again, my car isn't an honda accord. Link to comment Share on other sites More sharing options...
mountaindewguy Posted September 27, 2006 Share Posted September 27, 2006 40 bucks for the new one at the junkyard, 10 for the fluid = 50 dollars and 20 minutes. Link to comment Share on other sites More sharing options...
Attaus Posted September 27, 2006 Share Posted September 27, 2006 Yeah, because aren't they all universal? You just need new tubes. A new one from Advance (OEM) will run me $160. My rad is a piece of crap, however, and I would never consider buying a Denso or whatever it is again. I thought about picking up a Koyo, but they're $300 and that's for a good deal. Maybe a 1/2 size.. dunno. Link to comment Share on other sites More sharing options...
