Brandon Posted September 26, 2006 Share Posted September 26, 2006 im not to sure whats wrong with my car so if anyone has a clue your help would be appriated when i press on the gas my car sputters/putts with less power the normal. If i let go of the gas, and press again it stops... if I dont let go it spudders for up to 15 seconds and the exhoust smells bad. (I have a straight pipe) it does not do this all the time, only about 50% of the time. I think that its my O2 Senser. Thanks for your time! Link to comment Share on other sites More sharing options...
mycarsux Posted September 27, 2006 Share Posted September 27, 2006 If it was your O2 sensor you would be getting a check engine light. Are you getting this? Sounds like a fuel problem. Maybe its the main fuel relay, maybe its the fuel pump, idk. More information is nice. The more info you give the better we can help. Link to comment Share on other sites More sharing options...
Brandon Posted September 27, 2006 Author Share Posted September 27, 2006 ive had the car for 2 years and i bought it off a mechanic and the engine light has been on since i had it, he told me that it was ecm(i think thats what he said) that was kicking it on, and not to worrie about it. so i dont know if its has a new code. i wanted to get some opinions before i got the computer read. do you know where the fuel relay is? Link to comment Share on other sites More sharing options...
mycarsux Posted September 27, 2006 Share Posted September 27, 2006 haha, not exactly. just wait for someone knows to answer. Link to comment Share on other sites More sharing options...
Kastigir Posted September 27, 2006 Share Posted September 27, 2006 First, clear the code and then see what happens. If it throws a new code get it pulled and come back. Not before then. Link to comment Share on other sites More sharing options...
pd0019 Posted September 27, 2006 Share Posted September 27, 2006 i would say follow what mycarsux said. check your O2 sensor. i had a similar sputtering problem this summer w/ my check engine light turning on. its easy to diagnose and somewhat cheap to fix ($250 i think) and might solve all your problems. if it feels like there's something rattling on your tire when you pick up speed, check your axle boots and make sure that one of them didnt break either. Link to comment Share on other sites More sharing options...
