voided Posted September 28, 2006 Share Posted September 28, 2006 On my way home last night my clutch began to engage and disengage close to the floorboard, its a 1993 accord with about 183k on it no idea if clutch is original. 30 k I put on myself though. Before it engaged at 55% depressed and now its more like 85%. Im thinking it needs adjustment or a pedal spring replaced... It still drives fine its just a bit finicky to manage. Then This morning I start it up after checking and not seeing evidence of leaking and fluids seem fine as well... Now I cant get it in gear at all. So now im stuck 2 levels underground in a parking garage likely too steep to push out of and too low for a tow truck... lovely So any help would be appreciated Link to comment Share on other sites More sharing options...
mycarsux Posted September 28, 2006 Share Posted September 28, 2006 Your clutch is made of the same material as your brakes dude. It needs to be replaced. Its that simple, Link to comment Share on other sites More sharing options...
voided Posted September 28, 2006 Author Share Posted September 28, 2006 Your clutch is made of the same material as your brakes dude. It needs to be replaced. Its that simple, I was under the impression from reading other threads that if the clutch slips it needs replacing if not something else needs fixing Link to comment Share on other sites More sharing options...
mycarsux Posted September 28, 2006 Share Posted September 28, 2006 Oh i'm sorry I didn't really read your post too well. It could be the pressure plate not engaging because of a bad pedal assembly. So your first guess is probably right. Check the pedal springs and such. Also, your tranny is a cable tranny right? Could be a bad connection too. Link to comment Share on other sites More sharing options...
SolLesHonda Posted September 28, 2006 Share Posted September 28, 2006 93? Should be hydro. Link to comment Share on other sites More sharing options...
Jeffro Posted September 28, 2006 Share Posted September 28, 2006 If you've got fluid in the hydro reservoir, then I'd say replace your clutch... Slow deterioration like that is how mine went out in my 93 a couple years ago... And if you're stuck in a parking garage, I'd find out if anyone has a pickup that could pull you back up to ground level if that's your concern. That's when it somes in handy having a big a** truck laying around! (but not too big to get in a parking garage!) Link to comment Share on other sites More sharing options...
cranny Posted September 28, 2006 Share Posted September 28, 2006 I was under the impression from reading other threads that if the clutch slips it needs replacing if not something else needs fixing this would be correct. you need a new master or slave cylinder. unless its cable in which case you need a new cable. your pedal not feeling proper would have nothing to do with the clutch itself. its like you said , if it aint slippin , its good to go. Link to comment Share on other sites More sharing options...
mycarsux Posted September 28, 2006 Share Posted September 28, 2006 93? Should be hydro. Ahh, ok. I forgot the years where they became hydraulic and 93 seemed early. Ok so then yes I would say that you need a new master or slave cylinder. Link to comment Share on other sites More sharing options...
Kastigir Posted September 30, 2006 Share Posted September 30, 2006 Ahh, ok. I forgot the years where they became hydraulic and 93 seemed early. Ok so then yes I would say that you need a new master or slave cylinder. Replace them both at the same time. Replacing one or the other alone will only make the other one burn out more quickly. Link to comment Share on other sites More sharing options...
civic28236 Posted October 10, 2006 Share Posted October 10, 2006 hes right i would say so if you adjust pedal you will burn into the flywheel and then you will need one of them Link to comment Share on other sites More sharing options...
