xarcoush Posted October 3, 2006 Share Posted October 3, 2006 i have a 1999 honda accord ...steering wheel Shakes violently when braking at high speed 55 mph and above...I thought it was the rotors, so I got 4 brand new rotors and brand new ceramic pads but I am still having the same problem…it happens when I brake at high speed like 55mph and over, anything blow that it won’t shake .i would appreciate if you guys could help me ,,,thanks Link to comment Share on other sites More sharing options...
cranny Posted October 3, 2006 Share Posted October 3, 2006 if you put new rotors and pads on it and it still shakes , its either cheap brakes , bad install , or soin else wrong. id say your calipers are seized up some and sticking , meaning always putting pressure on rotors even when brake pedal is released and wearing them out faster. Link to comment Share on other sites More sharing options...
CleanGSR Posted October 3, 2006 Share Posted October 3, 2006 I currently have a bad rear tire (new one's on order) and my car shakes really bad if I do anything over light braking getting off the highway. Inspect all your tires and maybe have them re-balanced. Of course, as mine does, your car will have a shake to it period at highway speeds if a tire is bad or off balance; it just gets worse when you brake. Link to comment Share on other sites More sharing options...
xarcoush Posted October 3, 2006 Author Share Posted October 3, 2006 if you put new rotors and pads on it and it still shakes , its either cheap brakes , bad install , or soin else wrong. id say your calipers are seized up some and sticking , meaning always putting pressure on rotors even when brake pedal is released and wearing them out faster. One Of the calipers was seized up ..so i bought a new one ..i know the calipers are fine.. Link to comment Share on other sites More sharing options...
xarcoush Posted October 3, 2006 Author Share Posted October 3, 2006 It Wont shake unless i brake at speeds over 55MPH.. Link to comment Share on other sites More sharing options...
pd0019 Posted October 3, 2006 Share Posted October 3, 2006 i agree with hunggsr. check your tires, it could be that your balancing is off. Link to comment Share on other sites More sharing options...
mountaindewguy Posted October 3, 2006 Share Posted October 3, 2006 tires. Link to comment Share on other sites More sharing options...
OurStory Posted October 5, 2006 Share Posted October 5, 2006 4 new roters ? I thought only the front uses rotors and the back uses drums =S Link to comment Share on other sites More sharing options...
airjordan223 Posted October 5, 2006 Share Posted October 5, 2006 4 new roters ? I thought only the front uses rotors and the back uses drums =S depends on the model Link to comment Share on other sites More sharing options...
cranny Posted October 5, 2006 Share Posted October 5, 2006 if it was a tire it would shake all the time not just under braking. Link to comment Share on other sites More sharing options...
Evo_Jr Posted October 5, 2006 Share Posted October 5, 2006 if it was a tire it would shake all the time not just under braking. Thats hpw it was for my 4-door as well. I couldnt get on the highway because of the shake! I found out it was one of my steel rim and tire. Got 17's, and it rides fine. Go ahead and check the tires. Those are the only 2 i can think of off the top of my head. Tire & Breaks Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted October 5, 2006 Share Posted October 5, 2006 its not tires, either your brake disk is outof of balance or they are warped, also make sure the disk was installed on strait, is the two screws were tightened unevenly it disc could be calked off, it is not the wheels, other wise it wouldnt do it during just braking, it would do it under all driving conditions over 55mph Link to comment Share on other sites More sharing options...
