rus90 Posted October 17, 2006 Share Posted October 17, 2006 I think my fuel pump is gone. It doesn't want to start, when i turn the key on and off i can't here the pump activating? just wondering if anyone knows how tuff it is to change and how to do it? Thanks Rus Link to comment Share on other sites More sharing options...
Jeffro Posted October 17, 2006 Share Posted October 17, 2006 I think my fuel pump is gone. It doesn't want to start, when i turn the key on and off i can't here the pump activating? just wondering if anyone knows how tuff it is to change and how to do it? Thanks Rus What year? I know in my 6th gen, there's 3 bolts in the trunk under the carpet, and it lifts out... Not hard at all. Link to comment Share on other sites More sharing options...
rus90 Posted October 17, 2006 Author Share Posted October 17, 2006 What year? I know in my 6th gen, there's 3 bolts in the trunk under the carpet, and it lifts out... Not hard at all. 1990 Hoda accord lx Link to comment Share on other sites More sharing options...
rus90 Posted October 18, 2006 Author Share Posted October 18, 2006 1990 Hoda accord lx I cheked under carpet in the trunk, looks like there is something there that could resemble where a fuel pump might be? Link to comment Share on other sites More sharing options...
rus90 Posted October 18, 2006 Author Share Posted October 18, 2006 where do i look for the fuel filter? i just bought the car I,m not to fimiliar with it yet. Link to comment Share on other sites More sharing options...
xer0 Posted October 18, 2006 Share Posted October 18, 2006 if it set up like a civic then it is under hood left side Link to comment Share on other sites More sharing options...
Jeffro Posted October 18, 2006 Share Posted October 18, 2006 if it set up like a civic then it is under hood left side And if it's like mine, it's in the pump (there isn't really a "filter" like in the civics) Link to comment Share on other sites More sharing options...
cranny Posted October 18, 2006 Share Posted October 18, 2006 try putting a relay in it before you dismantle the car , lol. Link to comment Share on other sites More sharing options...
90Tegtyper Posted October 23, 2006 Share Posted October 23, 2006 take a test light and check if theres power gettting to the fuel pump wires Link to comment Share on other sites More sharing options...
rus90 Posted November 4, 2006 Author Share Posted November 4, 2006 take a test light and check if theres power gettting to the fuel pump wires I took the so called fuel pump out under the carpet and it's the fuel sending unit! Where's the pump??? and do i have to remove the tank \ Link to comment Share on other sites More sharing options...
mycarsux Posted November 5, 2006 Share Posted November 5, 2006 You're close. The fuel sending unit is part of the fuel pump. Link to comment Share on other sites More sharing options...
rus90 Posted November 5, 2006 Author Share Posted November 5, 2006 You're close. The fuel sending unit is part of the fuel pump. I took the sending unit out of the tank but theres no pump atached????? and only whiring comeing from unit no fuel lines??? Link to comment Share on other sites More sharing options...
rus90 Posted November 6, 2006 Author Share Posted November 6, 2006 I took the sending unit out of the tank but theres no pump atached????? and only whiring comeing from unit no fuel lines??? Still looking for help?? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 6, 2006 Share Posted November 6, 2006 try putting a relay in it before you dismantle the car , lol. Link to comment Share on other sites More sharing options...
rus90 Posted November 6, 2006 Author Share Posted November 6, 2006 where do ilook or find this relay?????????? Link to comment Share on other sites More sharing options...
prettibwoy Posted November 6, 2006 Share Posted November 6, 2006 i have the same car a 90 accord lx. when i hit the gas the car shimmies a little right below and up to 2000 rpms. but when i past that it runs fine. would this also be a fuel filter proble??? Link to comment Share on other sites More sharing options...
Joe W Posted November 6, 2006 Share Posted November 6, 2006 try putting a relay in it before you dismantle the car , lol. listen to cranny because chances are its your relay. I had a similar problem in my 89 crx and replaced the fuel pump still wouldnt start then replaced the main relay starts up great now. The relay in my crx is under the dash on the driver side not sure if thats where it is on your accord but wouldnt hurt to check Link to comment Share on other sites More sharing options...
daleb777 Posted November 7, 2006 Share Posted November 7, 2006 i have a 94 accord and i had to drain and drop the tank to replace mine... :( sorry for the bad news lol Link to comment Share on other sites More sharing options...
rus90 Posted November 7, 2006 Author Share Posted November 7, 2006 listen to cranny because chances are its your relay. I had a similar problem in my 89 crx and replaced the fuel pump still wouldnt start then replaced the main relay starts up great now.The relay in my crx is under the dash on the driver side not sure if thats where it is on your accord but wouldnt hurt to check I can't find no relay having anything to do with the fuel or pump. I looked under the dash in the fuse box and under the hood in the fuse box?????? Link to comment Share on other sites More sharing options...
Joe W Posted November 8, 2006 Share Posted November 8, 2006 look for your main relay im not sure there is a fuel pump relay. In my car it is right under the dash really close to the hood release lever. Not gonna lie was very diffucult to get to so good luck and I hope this helps Oh and if you dont have a manual like a haynes or something similar you might think about getting one not that expensive. They are not always right but they really do help out Link to comment Share on other sites More sharing options...
