bobobobo Posted October 31, 2006 Share Posted October 31, 2006 Installed new headlights. Disconnected battery. Now radio/cd/clock not working. Any ideas on how to get them to work? Thanks Link to comment Share on other sites More sharing options...
rspeach Posted October 31, 2006 Share Posted October 31, 2006 Installed new headlights. Disconnected battery. Now radio/cd/clock not working. Any ideas on how to get them to work? Thanks You will need to reconnect the battery. Prior to doing so make sure the connections are clean and tight. This applies to both the battery cables as well as the battery terminals. Link to comment Share on other sites More sharing options...
bobobobo Posted October 31, 2006 Author Share Posted October 31, 2006 You will need to reconnect the battery. Prior to doing so make sure the connections are clean and tight. This applies to both the battery cables as well as the battery terminals. The battery IS reconnected. And after doing so, none of this stuff works. Now what? Link to comment Share on other sites More sharing options...
B-Bomb Posted October 31, 2006 Share Posted October 31, 2006 The battery IS reconnected. And after doing so, none of this stuff works. Now what? Some sterio systems have an anti-theft device on them, meaning if you disconnect it from its power source, when you do turn it back on you have to put in an activation code. Do you remember ever setting an activation code? Link to comment Share on other sites More sharing options...
bobobobo Posted October 31, 2006 Author Share Posted October 31, 2006 Some sterio systems have an anti-theft device on them, meaning if you disconnect it from its power source, when you do turn it back on you have to put in an activation code. Do you remember ever setting an activation code? Oh yes. The code thing. Just found the code and will see if that will make things work. Thanks much Link to comment Share on other sites More sharing options...
21JumpStreet Posted November 6, 2006 Share Posted November 6, 2006 Oh yes. The code thing. Just found the code and will see if that will make things work. Thanks much if that doesn't work, try checking the fuses. i had a problem where every time i disconnected and reconnected my battery, i blew a fuse. Does the cig lighter work too? Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 6, 2006 Share Posted November 6, 2006 You will need to reconnect the battery. LMFAO. Link to comment Share on other sites More sharing options...
21JumpStreet Posted November 6, 2006 Share Posted November 6, 2006 LMFAO. Am i wrong? It happened to me so i guess it can happen to anyone. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted November 6, 2006 Share Posted November 6, 2006 No, i was quoting the guy who saaid he needed to reconnect his battery. I thought that was funny. Link to comment Share on other sites More sharing options...
21JumpStreet Posted November 6, 2006 Share Posted November 6, 2006 No, i was quoting the guy who saaid he needed to reconnect his battery. I thought that was funny. shi't i'm stupid. i should have see that. Link to comment Share on other sites More sharing options...
90IntegraC1 Posted November 6, 2006 Share Posted November 6, 2006 sooooo did it work? i was gonna say maybe you blew a fuse....but 21 beat me to it. Link to comment Share on other sites More sharing options...
