Dabbs93Accord Posted November 9, 2006 Share Posted November 9, 2006 Hello all, first time on the boards. Reason being, I had some trouble with my 93 accord the other night, as in it died right in the middle of a hill. It refused to start after it died. I ofcourse had to get it towed to where I work, at a service station ironically. The next morning when I came to work, I tried to start it, and what do you know, fired right up like nothing happened. This is my problem. I know it needs a main relay because I already had the won't start in hot weather issue. Problem is, it was cold out when my whole ordeal happened, not to mention I was driving when it happened. So basically my question is, could the relay be so bad that it would dis-engage in the middle of driving? Or is there something else I should look into first. I haven't driven the car much since the other night, and if it doesn't happen again, there isn't really a way to diagnose the problem. Any advice or experience with this problem would be greatly appriciated. Link to comment Share on other sites More sharing options...
Jeffro Posted November 9, 2006 Share Posted November 9, 2006 Would it not crank, or not fire when it cranked? Link to comment Share on other sites More sharing options...
IL3GL'88 Posted November 9, 2006 Share Posted November 9, 2006 i just had my main relay go out on mine and its a realy easy fix. Mine got so bad to the point that it wouldnt even start up in cold wheather but when i did get it started every once in a while, it never went out while i was driving. im guessing u got more goin on than just ur main relay. Link to comment Share on other sites More sharing options...
Dabbs93Accord Posted November 10, 2006 Author Share Posted November 10, 2006 i just had my main relay go out on mine and its a realy easy fix. Mine got so bad to the point that it wouldnt even start up in cold wheather but when i did get it started every once in a while, it never went out while i was driving. im guessing u got more goin on than just ur main relay. You could be right. Either way I need one anyhow, I just got it today and I will probably put it in tomorrow, we'll see what happens. Link to comment Share on other sites More sharing options...
Kastigir Posted November 11, 2006 Share Posted November 11, 2006 main relays typically keep a vehicle from starting. I've not known of one to go out while driving, though I assume it's possible. Link to comment Share on other sites More sharing options...
