zay386 Posted November 14, 2006 Share Posted November 14, 2006 alll my brake lights, signal, and reverse lights work but the brake lamp light is on driving lights work and all can someone tell me if they had that problem or how to fix it please thank u. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 14, 2006 Share Posted November 14, 2006 alll my brake lights, signal, and reverse lights work but the brake lamp light is on driving lights work and all can someone tell me if they had that problem or how to fix it please thank u. you might have the wrong bulb in there or you might have a bad fuse or something. check your fuses and then check the bulb Link to comment Share on other sites More sharing options...
Kastigir Posted November 16, 2006 Share Posted November 16, 2006 Faulty brake light switch. Replace and they should be fixed. Link to comment Share on other sites More sharing options...
coolcat467 Posted November 16, 2006 Share Posted November 16, 2006 Also could be a short somewhere. Link to comment Share on other sites More sharing options...
90Tegtyper Posted November 17, 2006 Share Posted November 17, 2006 Also could be a short somewhere. a short would probably blow the fuse or the bulb Link to comment Share on other sites More sharing options...
mycarsux Posted November 17, 2006 Share Posted November 17, 2006 No, I think a short will make the brake lights act weird. Not be on all the time. Link to comment Share on other sites More sharing options...
