HELP!!!! PLEASE HELP!!!!
accord_lxdude
Ok...so my 96 Accord LX has the power doors....I was trying to replace the power window regulator and in order to get inside I was trying to remove the door panel...only thing is that I did not take out the screw that's located on the inside of the door release handle...so I was pulling and pulling then....SNAP....dunno what happened but now, my power locks are staying locked! all of my doors are locked and I am not able to unlock ANY door!! What can I do? Is it something that I can fix from my house??? help me someone if ya can!!!! :help:
  • 4 weeks later...
pull on the door handle, then unlock the door, it happens sometimes when the regulator is wearing out and isnt getting enough power.
I'd like to open the whole door panel. Disconect all the connector. Clean it up with brake cleaner or electric cleaner. Then connect all the wire again BUT don't install the door panel yet. I want to see if the mechanism works. I will hear the sound of the whole door lock and unlock when I press the release button. But if don't, it means the mottor has problem. Before I change the mottor, I'll look at the fuse if it burns. It's a :D good try.
