ELLSSUU Posted January 1, 2007 Share Posted January 1, 2007 The headlights on my car suddenly dim, not a dangerous level but just a little bit dimmer, and then get bright often when I drive. There's no correlation to wether the car is stopped or moving or anything else that I can tell. Anyone else have this issue? Fix? I've thought about adding an extra ground to each headlight but..................... Link to comment Share on other sites More sharing options...
cranny Posted January 1, 2007 Share Posted January 1, 2007 could be faulty voltage regulator. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 1, 2007 Share Posted January 1, 2007 If its just the lights, then it most likely isn't the voltage regulator. If you saw all your gauges and stuff dim, then go back up then thats a possibility. check your connections to see if any are loose. Link to comment Share on other sites More sharing options...
