MiZz RUBIO Posted January 4, 2007 Share Posted January 4, 2007 :help: I have a 2004 Honda Accord Coupe and i have so many problems with it. 1st my blinkers are acting up. They flash too quick on the dashboard and outside, makes a funny noise. Could it be electrical or a burned bulb? Second, the seatbelt light shows up on the dashboard and it makes that noise even while i;m driving with my seatbelt on. Can anyone help? are there any recalls for my car? Link to comment Share on other sites More sharing options...
alex52e Posted January 4, 2007 Share Posted January 4, 2007 :help: I have a 2004 Honda Accord Coupe and i have so many problems with it. 1st my blinkers are acting up. They flash too quick on the dashboard and outside, makes a funny noise. Could it be electrical or a burned bulb? Second, the seatbelt light shows up on the dashboard and it makes that noise even while i;m driving with my seatbelt on. Can anyone help? are there any recalls for my car? I'm not sure about the seatbelt buzzer, but every time I have had a fast blinking light was due to a blown out bulb. Check and make sure that ALL the bulbs are working on your car. If just one is blown out, it could cause the fast blinking. Link to comment Share on other sites More sharing options...
MiZz RUBIO Posted January 4, 2007 Author Share Posted January 4, 2007 I'm not sure about the seatbelt buzzer, but every time I have had a fast blinking light was due to a blown out bulb. Check and make sure that ALL the bulbs are working on your car. If just one is blown out, it could cause the fast blinking. thanks so much...i'm gonna give it a try to see if that's it. Link to comment Share on other sites More sharing options...
Spoonkid Posted January 9, 2007 Share Posted January 9, 2007 no open bulletin's on your car... I'll keep checking for you. If your blinker's are still acting up, you may need a switch. Link to comment Share on other sites More sharing options...
MiZz RUBIO Posted January 9, 2007 Author Share Posted January 9, 2007 no open bulletin's on your car... I'll keep checking for you. If your blinker's are still acting up, you may need a switch. i've been told it might be the switch and i've heard thats it's expensive b/c they have to take the steering wheel apart. do u have an idea of why that would happen or how much would it cost. Link to comment Share on other sites More sharing options...
mycarsux Posted January 9, 2007 Share Posted January 9, 2007 Your turn signal bulb is about to burn out. Replace em all just for good measure. They're not expensive. Is there something on the passenger seat? If so the car thinks someone is sitting in it so it flashes the seatbelt light. Link to comment Share on other sites More sharing options...
Spoonkid Posted January 9, 2007 Share Posted January 9, 2007 your "flashing seat belt" is probably a loose connection in the seat belt. The OPDS WILL NOT make your seat belt light come one. That's only for the passenger seat. Your headlight switch would be $28.00 plus labor. Link to comment Share on other sites More sharing options...
