BeTeP Posted January 6, 2007 Share Posted January 6, 2007 Last Wednesday I bought a 03 accord coupe V6 6speed. It's my first Honda - before I've had a 98 540iA which I sold on 1/1/07(too many check engine problems and maintenance cost.) I'm a member of bimmerforums.com as well. How do You guys drive these??!? Under hard acdeleration It's just impossible to hold the car on the road It starts jumping! Even With TCS. and I'm not talking off the line!!!Am I doing something wrong?? may be I just got used to BMWs where You don't get as much wheelspin even with 6 speed. Let's get to my questions - the car has 65K miles - as I've read in the manual it's tune up free till 100K, but may be I should look into something. When I'm driving in any gear @60mph and start accelerating the steering wheel starts shaking. Tires??? they're average - not new ,but not bald too. When Braking pedal vibrating and steering wheel shaking as I understand it's Rotors. Should I cut them? or should I replace them? If reokacing which brand and what kind to get. Where do You guys get good quality parts?? and is there an online parts database where You enter Your VIN and thel look at pictures and part numbers like for BMW www.realoem.com Any response is appreciated. Thanks o:) Link to comment Share on other sites More sharing options...
Kastigir Posted January 6, 2007 Share Posted January 6, 2007 Sounds like you need your wheels balanced. Typically Honda rotors aren't terribly expensive, so you're usually better off replacing them. http://www.hondaautomotiveparts.com/home.htm This is a good OEM online parts dealer. Link to comment Share on other sites More sharing options...
Kegger Posted January 7, 2007 Share Posted January 7, 2007 Or you can upgrade.... Link to comment Share on other sites More sharing options...
brewsky* Posted January 8, 2007 Share Posted January 8, 2007 Or you can upgrade.... Yea- you just need to balance your tires. Maybe rotate them if the front ones are worn down a bit more than the back ones. The vibration generally occurs durin the 50-65 mph range. Link to comment Share on other sites More sharing options...
BeTeP Posted January 8, 2007 Author Share Posted January 8, 2007 Should I buy Original Rotors or there are better rotors out there??? Crossdrilled and/or slotted of eBay good??? Link to comment Share on other sites More sharing options...
brewsky* Posted January 10, 2007 Share Posted January 10, 2007 Should I buy Original Rotors or there are better rotors out there??? Crossdrilled and/or slotted of eBay good??? Im looking for the same. If you come across a good deal let me know. Link to comment Share on other sites More sharing options...
xer0 Posted January 10, 2007 Share Posted January 10, 2007 watch out on ebay u get what u pay for Link to comment Share on other sites More sharing options...
Jeffro Posted January 10, 2007 Share Posted January 10, 2007 I have an 00 with 172,000 miles and I still have the original rotors, so either Honda went cheap on the '03's or I wouldn't worry too much about replacing them. If you are replacing them at 65,000 miles because they need it, then I wouldn't get OEM replacements. Drilled and slotted aren't particularly going to make a difference as far as quality goes, so I've heard. Brembo is what I've heard recommended for my accord. Link to comment Share on other sites More sharing options...
