deadskinmask Posted January 15, 2007 Share Posted January 15, 2007 I just installed a jdm f22a1 in my 91 accord and i cant get it to start. the motor turns but backfires. I found that the timing was 2 teeth off but that was reference from the original f22a1 motor. I still have the same problem but im not sure if the timing is set different for the us and jdm versions. I also did a compression test and everything checked out fine. so if anyone has any idea on what could be causing it let me know. Link to comment Share on other sites More sharing options...
mikekrier07 Posted January 15, 2007 Share Posted January 15, 2007 check the spark plug wires u might have them in the wrong order...thats what happend 2 my friends prelude same excact problem Link to comment Share on other sites More sharing options...
cranny Posted January 15, 2007 Share Posted January 15, 2007 its definitely a timing issue , either with the belt or wrong firing order for sure. that said , im assuming everything is working order. Link to comment Share on other sites More sharing options...
mikekrier07 Posted January 15, 2007 Share Posted January 15, 2007 any luck? Link to comment Share on other sites More sharing options...
deadskinmask Posted January 15, 2007 Author Share Posted January 15, 2007 alright thanks im about to go mess with it right now and see what i can do Link to comment Share on other sites More sharing options...
mikekrier07 Posted January 16, 2007 Share Posted January 16, 2007 post back up when u get the chance and tell us what it was? Link to comment Share on other sites More sharing options...
