jetmech09 Posted January 17, 2007 Share Posted January 17, 2007 1993 accord runs fine till you try to Accelerate fast. The engine will stumble and missfire. It also has another problem, if you turn on the Airconditioner it will not kick up the idle. Please help. :help: Link to comment Share on other sites More sharing options...
Hatch92 Posted January 17, 2007 Share Posted January 17, 2007 when was the last tune up? Link to comment Share on other sites More sharing options...
cranny Posted January 17, 2007 Share Posted January 17, 2007 yeah sounds like tuneup issues , cap and rotor , plugs , wires. Link to comment Share on other sites More sharing options...
yamamotor Posted January 17, 2007 Share Posted January 17, 2007 At what RPM does the misfire. Is it only when taking off from stops? Could be clogged EGR ports. Link to comment Share on other sites More sharing options...
jetmech09 Posted January 18, 2007 Author Share Posted January 18, 2007 At what RPM does the misfire. Is it only when taking off from stops? Could be clogged EGR ports. it happens once the engine is at operating temp. Runs fine till it warms up. It will missfire till about 3,000RPM. If you hit the accelerator and go into the passing gear it will clear up at about 3,000 Rpm. Link to comment Share on other sites More sharing options...
sk8er722 Posted January 21, 2007 Share Posted January 21, 2007 I have the same problem. You start going, studer, studer, studer, 3000 RPM you rocket off. (you know what I mean) Link to comment Share on other sites More sharing options...
jetmech09 Posted January 26, 2007 Author Share Posted January 26, 2007 I have the same problem. You start going, studer, studer, studer, 3000 RPM you rocket off. (you know what I mean)yeah, thats exactly what it does. Link to comment Share on other sites More sharing options...
jetmech09 Posted February 1, 2007 Author Share Posted February 1, 2007 yeah, thats exactly what it does. Cap, rotor,plugs,wires and new coil fixed it........... Link to comment Share on other sites More sharing options...
Kegger Posted February 1, 2007 Share Posted February 1, 2007 Oh and the A/C problem is probably oyur idle air control valve. My old accord did that too and I had to replace the IACV to fix it. Link to comment Share on other sites More sharing options...
RBARRETT Posted February 1, 2007 Share Posted February 1, 2007 1993 accord runs fine till you try to Accelerate fast. The engine will stumble and missfire. It also has another problem, if you turn on the Airconditioner it will not kick up the idle. Please help. :help: I have the same car and the same problem! It's only when the engine is accelerating that it misses.. I have relaced the plugs,rotor,distributor cap and it's still doing it..I'm leaning toward fuel issues?? Link to comment Share on other sites More sharing options...
RBARRETT Posted February 1, 2007 Share Posted February 1, 2007 I have the same car and the same problem! It's only when the engine is accelerating that it misses.. I have relaced the plugs,rotor,distributor cap and it's still doing it..I'm leaning toward fuel issues?? Just figured mine out and it was plug wires. I started it and pulled each plug wire one at a time found the cylinder and it was arking through the plastic piece that fits over the plug. It had a small burn hole through it...Yee haw Link to comment Share on other sites More sharing options...
jetmech09 Posted February 2, 2007 Author Share Posted February 2, 2007 Just figured mine out and it was plug wires. I started it and pulled each plug wire one at a time found the cylinder and it was arking through the plastic piece that fits over the plug. It had a small burn hole through it...Yee hawgood job!! glade you found the problem. Link to comment Share on other sites More sharing options...
