jetmech09 Posted February 2, 2007 Share Posted February 2, 2007 1993 accord 2.2. my oil light is now flashing. what the heck is this trying to tell me? The engine runs fine, no wierd noises, and no overheat. just drove it 50 miles and the engine did not blow up lol lol lol. Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 its telling u to check your oil Link to comment Share on other sites More sharing options...
jetmech09 Posted February 2, 2007 Author Share Posted February 2, 2007 its telling u to check your oiloil level is ok Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 well when the last time u changed it? Link to comment Share on other sites More sharing options...
jetmech09 Posted February 2, 2007 Author Share Posted February 2, 2007 well when the last time u changed it?its been almost 3000 miles. do you think the oil viscosity has broken down? Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 not with only 3000 miles. u probably need a new oil pump Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 googled clicky Link to comment Share on other sites More sharing options...
jetmech09 Posted February 2, 2007 Author Share Posted February 2, 2007 googled clicky how hard is it to change the oil pump in a 93 accord 2.2? Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 lol no clue. might have to wait for other ppl to come on to answer taht one. try looking on this site http://www.hondahookup.com/manuals/ Link to comment Share on other sites More sharing options...
coolcat467 Posted February 2, 2007 Share Posted February 2, 2007 I thought some hondas had a thing where the check oil light came on every so many miles. Just to remind people that the time has come. Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 from waht i was been reading oil light = either low oil,no oil pressure,or a faulty sensor. jetmech09 how cold is it where u live? Link to comment Share on other sites More sharing options...
Jeffro Posted February 2, 2007 Share Posted February 2, 2007 I thought some hondas had a thing where the check oil light came on every so many miles. Just to remind people that the time has come. The maintenance required light turns on, not the check oil light in what yo're referencing. In your Accord, I believe it goes from green to red until you reset it. The oil light is something different entirely. Link to comment Share on other sites More sharing options...
coolcat467 Posted February 2, 2007 Share Posted February 2, 2007 Yea, that's what I meant. Thanks. Link to comment Share on other sites More sharing options...
jetmech09 Posted February 2, 2007 Author Share Posted February 2, 2007 from waht i was been reading oil light = either low oil,no oil pressure,or a faulty sensor. jetmech09 how cold is it where u live? I live in Miami Fl. about 75 average. Link to comment Share on other sites More sharing options...
xer0 Posted February 2, 2007 Share Posted February 2, 2007 then i stick whit my ges of u need a new oil pump... if it was like -20 out where u live might just be the oil being slugish Link to comment Share on other sites More sharing options...
cranny Posted February 2, 2007 Share Posted February 2, 2007 im betting on sensor. Link to comment Share on other sites More sharing options...
jetmech09 Posted February 3, 2007 Author Share Posted February 3, 2007 im betting on sensor. Im gonna change the sensor and the oil. Link to comment Share on other sites More sharing options...
Ben. Posted February 3, 2007 Share Posted February 3, 2007 Good choice. Start small.. if it continues, then you're gonna have to swap the pump. Nothing like some hot Miami winter weather too, ? ;) Link to comment Share on other sites More sharing options...
otto888man Posted February 5, 2007 Share Posted February 5, 2007 1993 accord 2.2. my oil light is now flashing. what the heck is this trying to tell me? The engine runs fine, no wierd noises, and no overheat. just drove it 50 miles and the engine did not blow up lol lol lol. Did you just had an oil change? If so , they might have put in the wrong viscosity. I would suggest to have an oil change before doing something else. Om Link to comment Share on other sites More sharing options...
xer0 Posted February 5, 2007 Share Posted February 5, 2007 well when the last time u changed it? its been almost 3000 miles. do you think the oil viscosity has broken down? read post and soe tiems u find the answer.. but welcome to HF otto888man Link to comment Share on other sites More sharing options...
cranny Posted February 5, 2007 Share Posted February 5, 2007 his oil being thinner would not make the oil light come on. Link to comment Share on other sites More sharing options...
trifling Posted February 5, 2007 Share Posted February 5, 2007 read post and soe tiems u find the answer.. but welcome to HF otto888man Sorry so late but if you still wanna know. It is very complicating to chagne the pump if you have not done it before.More than likely 80/20 it is you oil pressure sensor. Of course if it was your pump you would be sol right now having driven that many miles. Oil light only flashes during low oil levels and sensor failure, well sometimes failure.First easier if you take off p/s and alt.Sorry valve cover first. Than timing cover.(bottom and top).And yes there is ways to avoid the mount but easier to take it off.Then with nuthin but the side of the block showing(crank pulley has to come off also)than take off the balance shaft belt. On the gear to the right wich is the balance shaft there is a gear wich you also have to line up like timing but you can be off. If you want you can take the bolt off from directly in back (about 3 or 4 in in on the right it is located). than take a 10mm bolt about four inches in length and put it into the hole where you took the bolt out from. Turn the gear on the right and apply pressure to the bolt in back and you will feel when it goes into place. That will alighn the shaft. Or else on the gear itself there is actually a notch in it that you can line up with the block. that is only the beginig. Than there is the gear on the pump itself. Making it short. The bolts on the oil pump, take them off. Reverse the process. But when you do get it on.. there is a notch also on the oil pump shaft wich you have to align 120clock.(Forgot, you have to pretty much do a timing belt like procedure.Cause you have to loosen the tensioner But if you want you could just slide it off the balace shaft gear.)If you want to know step by step post again. Maybe wont b so tired to type it all.All in all run the engine and take the oil cap off to see if oil is actually lubing the cam shaft or spurting around in there.If it is than the oil pump is good, old mech trick.(Sorry should have post that first.)Accords your year that I fixed has always for me just been the oil pump seal and not the actual pump. But you said you got oil so it aint the seal wich is common for accords to have failure in. Link to comment Share on other sites More sharing options...
overdubbed Posted February 6, 2007 Share Posted February 6, 2007 The same thing is happening to me... (1992 Honda Accord EX) it just started this week. I'll post a video of it on youtube when I have a chance... frustrating as hell... since the car runs fine/always has been well maintained and the oil level is correct. OP did you figure out what was going on/did were able to fix it? Link to comment Share on other sites More sharing options...
91_Accord_Tuner Posted February 16, 2007 Share Posted February 16, 2007 Yep souinds like you need a new oil pump... or possibly your oil sending unit is bad, i have seen that happen before, oh yeah and check your oil pressure switch it could be bad or have a bad wire in the circuit. not with only 3000 miles. u probably need a new oil pump Link to comment Share on other sites More sharing options...
