nklimek Posted February 26, 2007 Share Posted February 26, 2007 ok, so i have a 2000 honda accord v6. At 104000 miles me and my buddy did a timing belt change and i used a belt from autozone(probably a bad idea). THen the other night i was driving down the highway on cruse at 65mph and the timing belt jumped teeth and ripped a hole in the belt cover. THis was only 5 thouand miles after i changed the belt. We took the covers and stuff of and found out that the bolt that holds the belt tensioner on had broken and the pulley fell off. I think the bolt broke because the hydraulic piece that pushes the tensioner felt locked up!! Y would it lock up??? any advice is appreciated Link to comment Share on other sites More sharing options...
cranny Posted February 26, 2007 Share Posted February 26, 2007 sounds like it was too tight to me. if there too tight it puts a crap kicking on the tensioner. Link to comment Share on other sites More sharing options...
nklimek Posted February 26, 2007 Author Share Posted February 26, 2007 sounds like it was too tight to me. if there too tight it puts a crap kicking on the tensioner. ITS AN AUTOMATIC TENSIONER, SO I THINK IT WAS LOCKED UP BECAUSE IT IS frackED UP. Link to comment Share on other sites More sharing options...
Spoonkid Posted February 26, 2007 Share Posted February 26, 2007 the only belts that should be used on Honda's are Gates belts... not Autozone garbage... Link to comment Share on other sites More sharing options...
nklimek Posted February 26, 2007 Author Share Posted February 26, 2007 the only belts that should be used on Honda's are Gates belts... not Autozone garbage... well i got a oem honda one from the dealership this time, only 40$. not to bad really. Link to comment Share on other sites More sharing options...
Kastigir Posted March 1, 2007 Share Posted March 1, 2007 Should've replaced the tensioner when you replaced the belt. Link to comment Share on other sites More sharing options...
