ESPEJO Posted March 19, 2007 Share Posted March 19, 2007 i am doing a motor swap i have a 95 accord i am dropping a H22a in it, i was told that i could use the wire harness off my 95 accord, is this true? both engines are OBD1 and both are 95 motors.... now the only thing is that my motor is non V-tec and the H22a is of course a V-tec, my next question would be if all OB1 harness are the same for Honda's can i use a wire harness from a 1995 Honda that is V-tec????? or if any one out there has a H22a wire harness i would like to buy.... Link to comment Share on other sites More sharing options...
frizzy210x2 Posted March 30, 2007 Share Posted March 30, 2007 u need the h22a computer and i believe some1 makes a harness were everything plugs in for the accord 2 h22a if not u have to wire in vtec from the vtec selenoid to the computer Link to comment Share on other sites More sharing options...
cranny Posted March 30, 2007 Share Posted March 30, 2007 you need a P13 ECU. and you need to pin and run a few wires for vtec. knock sensor , VTEC pressure switch(and a ground) , VTEC solenoid. Link to comment Share on other sites More sharing options...
