brian.taylor Posted March 31, 2007 Share Posted March 31, 2007 I'm leaking oil out of one of the bolts between the spark plugs on the valve cover. When I go to the parts store, what do I ask for? Is it a valve cover grommet? Link to comment Share on other sites More sharing options...
Ben. Posted March 31, 2007 Share Posted March 31, 2007 Valve cover gasket. Link to comment Share on other sites More sharing options...
Dabbs93Accord Posted April 2, 2007 Share Posted April 2, 2007 Well you will need the grommets, but also the valve cover gasket itself. Pretty simple fix. Clean the valve cover and surfaces up well. The grommets probably won't be easy to get out, but not impossible by any means. Get some RTV and put a dab or two on the corners. May not seem to make sense but you'll see what I mean. Link to comment Share on other sites More sharing options...
