///MPower Posted April 1, 2007 Share Posted April 1, 2007 Hello, I have a 94 Accord EX and when I drive it, the speedometer will stay at 19-20 mph, even when I'm at a stand still, it still says that. And everyone once in awhile, it will start working again just Fine. I don't get whats causing it? Could it be a Bad Sensor or does the Whole Cluster Have to Be Replaced?? Any Suggestions would be helpful Thanx in Advance Link to comment Share on other sites More sharing options...
Dabbs93Accord Posted April 2, 2007 Share Posted April 2, 2007 Probably a bad Vehicle speed sensor. Is your check engine light on? Link to comment Share on other sites More sharing options...
///MPower Posted April 3, 2007 Author Share Posted April 3, 2007 Probably a bad Vehicle speed sensor. Is your check engine light on? No it isnt......Do you know where the sensor could be located? Link to comment Share on other sites More sharing options...
2kflhr Posted April 4, 2007 Share Posted April 4, 2007 From the right side of the car look behind motor, just to the right of center you will see it. It has plug going into it you can see 3 phillips screws holding the sensor part on, the whole unit is fastened with 2 bolts. Mine worked erratically so I bought one on e-bay for $12.99 + $12.99 shipping with a lifetime warranty. The Honda dealer (or should I say, stealer) wanted $154.00+ for the unit. I'll take my chances to save $125.+ Link to comment Share on other sites More sharing options...
Dabbs93Accord Posted April 11, 2007 Share Posted April 11, 2007 No it isnt......Do you know where the sensor could be located? They usually work through the Tranny, but that's all I know as I've never actually had to mess with one. Link to comment Share on other sites More sharing options...
Kegger Posted April 11, 2007 Share Posted April 11, 2007 Top of the tranny towards the firewall. Should pull out, at least mine does. Link to comment Share on other sites More sharing options...
///MPower Posted April 20, 2007 Author Share Posted April 20, 2007 Top of the tranny towards the firewall. Should pull out, at least mine does. Thanx......I'll check it out Link to comment Share on other sites More sharing options...
