Mr.Steve Posted April 5, 2007 Share Posted April 5, 2007 Hey, Im Steve. I Recently had my clutch master cylinder replaced. Its been working great for about the past week or so but now its making a loud sqeeking noise from outside the car when i press my clutch down. Its sounds like a loud un-lubed spring noise if that helps. I have visted some of the other clutch-related topics and couldn't find anything that really helps me out. If someone could offer some advise that would be cool. Link to comment Share on other sites More sharing options...
cranny Posted April 6, 2007 Share Posted April 6, 2007 its probably your pressure plate , could go away with time. where the clutch fork goes through the housing , you can put grease on the plunger but i bet on pressure plate. have someone step on it while your under hood see if it sounds like its comming from inside tranny. Link to comment Share on other sites More sharing options...
crxtacy Posted April 6, 2007 Share Posted April 6, 2007 Try checking the slave cylinder.I just had one making the squeaking noise. Link to comment Share on other sites More sharing options...
cranny Posted April 6, 2007 Share Posted April 6, 2007 lol Link to comment Share on other sites More sharing options...
Mr.Steve Posted April 6, 2007 Author Share Posted April 6, 2007 Humm, Well it looks like this is the exact part that is making the noise i had a buddy press my clutch down and its coming from this part.......Im sorry for the crap pic buts its late and im drunk 3:05am heh heh....should i WD-40 it? Link to comment Share on other sites More sharing options...
Mr.Steve Posted April 6, 2007 Author Share Posted April 6, 2007 Heres a better pic of where its coming from.........If you can see the red outlines.....the 1st pic is a "close up" Link to comment Share on other sites More sharing options...
crxtacy Posted April 6, 2007 Share Posted April 6, 2007 Thats the clutch slave cylinder Link to comment Share on other sites More sharing options...
Mr.Steve Posted April 7, 2007 Author Share Posted April 7, 2007 well cool, should i attempt to spray some WD-40 on the clutch slave or will that do anything good at all?....This damn sqeaking noise is a f*cker to listen too.... Link to comment Share on other sites More sharing options...
99HondaAccord Posted April 8, 2007 Share Posted April 8, 2007 Are you sure its not a belt??? Touch the metal end of a screwdriver to various parts of your car and the other end to your ear. This will help determine EXACTLY where your squeaking is coming from. Link to comment Share on other sites More sharing options...
cranny Posted April 8, 2007 Share Posted April 8, 2007 i told him in the very first post to grease the plunger. Link to comment Share on other sites More sharing options...
Dedicated2Honda Posted April 10, 2007 Share Posted April 10, 2007 haha. you have come across the biggest problem when fixing a car. if you fix something, it will break something else. you usually want to replace the master and slave cylinders together. you want them working at about the same ability. Link to comment Share on other sites More sharing options...
