buclao Posted April 13, 2007 Share Posted April 13, 2007 been reading some of the posts and some say the sensor is what makes the speedo go nuts....my sensor was changed and it still does the same thing...i also changed my cluster... what should i do??? sensor or cluster??? also i was looking around ebay, and saw some no name brand springs... are they worth buying???? Link to comment Share on other sites More sharing options...
Kegger Posted April 13, 2007 Share Posted April 13, 2007 Check your speedo cable. Don't touch no-name ebay suspension parts, you'll end up with a bad back in about a week. Link to comment Share on other sites More sharing options...
buclao Posted April 13, 2007 Author Share Posted April 13, 2007 i did check the speedo plugs and it seems ok... thanks for the advice on the springs... Link to comment Share on other sites More sharing options...
2kflhr Posted April 14, 2007 Share Posted April 14, 2007 i did check the speedo plugs and it seems ok... thanks for the advice on the springs... I just changed my VSS hoping that was the problem. However, it wasn't. I have checxked all of the connections. What mine does is it will all of a sudden start working while driving and may work until I get to my destination and sometimes will only work for several miles. I'm now wondering if it's the gauge. Link to comment Share on other sites More sharing options...
