Check engine Light/Catalytic convertor
Manish
Hi, I have recently bought a used 1998 Honda Accord. Just after the registration is showing the Check Engine Light(CEL). I went to a Mechanic he told me the poblem is with Catalytic convertor and error code is P0240. He said that he has to change the Catalytic Convertor.
I checked with two mechanic they are saying it will cost around $300 to replace it . They are not going for original OEM part.
By putting a Convertor from some other company i.e. Boscal or Eastern will solve my problem?
As I have to go for inspection check also. I am not in a position to shell out $1000 for OEM part.
Thanks for help
