does anyone know how to change an ignition?
zay386
i have a 92 accord and last month the door chimes was fading in and out and as of tonight every time i tried to start the car it cut off but when i held the key it stayed on. I just need to know if anyone knows how to replace the key lock cylinder?
its not the lock cylinder.its the ignition switch.just remove the steering cover and right there where the ignition assembly is there is the switch .its a black/yellow wire and i think its black /white wire.
[/quote
thanks i took the switch out relpaced it and it started right up with no problems
