Seany_C Posted May 24, 2007 Share Posted May 24, 2007 I am in the process or removing a bad alternator on a 92 Civic. The top two bolts came out fine and I got the nut off of the lower bolt. My problem is that the lower bolt is correded into the mount. How can I get this thing out short of torching it (No torch available)? Link to comment Share on other sites More sharing options...
cranny Posted May 24, 2007 Share Posted May 24, 2007 spray penetrating lube on the seam , have the belt off and top bolt out , and keep prying it back and forth , back and forth till it loosens up. than using ratchet extensions and a hammer , start trying to punch the long bolt out from the drivers side wheel well. it will come. make sure you leave the nut on the long bottom bolt just enough so the threads are flush with the top of the nut. if not youl mushroom the end and make it unusable. make sure you can pry it back and forth loosly by hand before beating on it , lol. before reinstalling new alternator , the bottom bracket on the engine has on one side a little slider , make sure you beat it open again , otherwise it will be a pain in the ass to get the new alternator into the bottom bracket. Link to comment Share on other sites More sharing options...
crxtacy Posted May 25, 2007 Share Posted May 25, 2007 I used one of those portable propane torch to heat up that rusty old bolt.But the penetrating oil would do the trick . Link to comment Share on other sites More sharing options...
Seany_C Posted May 25, 2007 Author Share Posted May 25, 2007 Thanks for the tips guys. I will try this later on and see if it get that thing off. Link to comment Share on other sites More sharing options...
