AcesFullof10s Posted May 25, 2007 Share Posted May 25, 2007 How can I get the heater/AC unit out of the dash? What kind of bulbs are used to illuminate the unit? Thanks! Link to comment Share on other sites More sharing options...
TrailMystic Posted May 27, 2007 Share Posted May 27, 2007 Remove the counsol between the seats Remove the radio Dlsconnect the air mix control cable from the hearter unit Remove the self-tapping screw from behind the fan speed control knob. Disconnect the connectors and remove the heater control panel. What went bad on your unit? My fan speed control crapped out. Pete Link to comment Share on other sites More sharing options...
jonjon Posted March 18, 2009 Share Posted March 18, 2009 My lights went out behind the heater controls as well....I have a question on removal so I can replace the wedge bulbs...... When you say..... " Disconnect the connectors and remove the heater control panel." in the prior note How do you disconnect the connectors? Where are the connectors you are referencing?.... The faceplate of the heater control panel is wedged in tight. I've tried to use a flat screwdriver and pry it off but I'm getting nowhere.....Please help....thanks ....Jon Link to comment Share on other sites More sharing options...
