jjcuff1 Posted June 8, 2007 Share Posted June 8, 2007 Driving early am in dark and light by the time I get to work I easily forget my headlights are since the dash lights and AC lights are never visible unless it is pitch black. I have dropped my battery twice now. Is there a simple alarm or timer conversion? Link to comment Share on other sites More sharing options...
TS John Posted June 8, 2007 Share Posted June 8, 2007 Turn up the dash and AC lights with the little dial on the cluster. That's a lot easier than adding a warning. Link to comment Share on other sites More sharing options...
reewinder Posted June 8, 2007 Share Posted June 8, 2007 I have had the same thing happen 2 or 3 times. All it takes is 30 minutes and my battery is drained. I haven't added a buzzer yet but here is a link for a how-to on installing a lights on reminder. Hope it works for you. And if you can't solder then just get male/female wire connectors. http://teamdelsolwa.com/howto/buss.htm Link to comment Share on other sites More sharing options...
TS John Posted June 8, 2007 Share Posted June 8, 2007 Wow. That looks surprisingly easy. Maybe I'll do that in my sol, even though I've never done that. Link to comment Share on other sites More sharing options...
blackdelsol Posted June 9, 2007 Share Posted June 9, 2007 or you could just get a del Sol VTEC. you would get the head light warning, with 60 more hp on the side Link to comment Share on other sites More sharing options...
Humphries Posted June 9, 2007 Share Posted June 9, 2007 if you open the door when the lights are on there's a buzzer that's supposed to go off. or do S models not have that feature? Link to comment Share on other sites More sharing options...
TS John Posted June 9, 2007 Share Posted June 9, 2007 My s model didn't. Not sure if my snazzy new si will. Link to comment Share on other sites More sharing options...
reewinder Posted June 9, 2007 Share Posted June 9, 2007 I know if you leave the keys in the ignition and open the door a buzzer/chime goes off. I have never been aware that the VTEC models came with lights on buzzer. You might be mistaken. Perhaps someone allready did the modification on your car? Link to comment Share on other sites More sharing options...
