pudder Posted June 23, 2007 Share Posted June 23, 2007 when i drive on the highway the anti freez leaks from the plastic bottle where i put the anti-freez and my radiator becomes empty. what can be the probles of the car. Link to comment Share on other sites More sharing options...
Ben. Posted June 23, 2007 Share Posted June 23, 2007 Does it smoke at all? Radiator cracked? Link to comment Share on other sites More sharing options...
pudder Posted June 23, 2007 Author Share Posted June 23, 2007 radiator looks good and i dont see any smoke Link to comment Share on other sites More sharing options...
Ben. Posted June 23, 2007 Share Posted June 23, 2007 Your reservoir is probably cracked somewhere or something. Thus it's inability to hold water.. Or you've got a cracked hose.. Orrrr a high pressure leak somewhere..Just have to look. Link to comment Share on other sites More sharing options...
cranny Posted June 23, 2007 Share Posted June 23, 2007 must be a wet spot somewheres dude after leaking that much. Link to comment Share on other sites More sharing options...
pudder Posted June 23, 2007 Author Share Posted June 23, 2007 can it be the radiator cap and if it is how can i tell its broken by just looking at the cap. Link to comment Share on other sites More sharing options...
Red90SI Posted June 23, 2007 Share Posted June 23, 2007 yea if you look at the ratiator cap n the rubber seal looks really worn or broken its time to replace it then you will have an air leak in ur system n a possible fluid leak but not enugh to drain ur whole system check n see if the o rings on your drain plug on the bottom of the ratiator are still good you could also be leaking from there... Link to comment Share on other sites More sharing options...
pudder Posted June 24, 2007 Author Share Posted June 24, 2007 thanks Link to comment Share on other sites More sharing options...
TheJGB3 Posted February 7, 2008 Share Posted February 7, 2008 Every cooling system is a "closed" system, (pressure only builds when you shut off the engine at operating temp. (195 degrees F)) this is when the system will leak if you have a leak. The only way to test a radiator cap is to pressure test it. You use a cooling system pressure tester. First you can pressure test the cap, and if it holds pressure, then pressure test the cooling system. You test the cap by attaching it to the pressure tester. To test the cooling system, you attach the pressure tester where the rad cap goes on top of the radiator then pump it up to 12lbs. You can get one at Advance Auto or Autozone. In their "free" loan a tool program, you buy the part (Autozone's price is $79.99), and you get your money back when you return it to the store you got it from. Autozone will let you keep it as long as you need it. Advance Auto only gives you 90 days. Either way that is plenty of time. I know GM cars are 15lbs., I think Honda is 12lbs. but I could be wrong. Link to comment Share on other sites More sharing options...
FreshDaily Posted February 8, 2008 Share Posted February 8, 2008 yep thats probably your best bet like JGB said. Go to autozone and borrow a pressure tester and do your tests. See if any water leaks from anywhere or if your hear a light bubbling and pin point it! Test the cap as well! Link to comment Share on other sites More sharing options...
airjordan223 Posted February 8, 2008 Share Posted February 8, 2008 this is from last summer, he probably figured it out by now Link to comment Share on other sites More sharing options...
Hatch92 Posted February 8, 2008 Share Posted February 8, 2008 Agree this thread waaas dead. Link to comment Share on other sites More sharing options...
