Pnizz Posted August 13, 2007 Share Posted August 13, 2007 What are my options to rebuild/replace my stock 97 accord 4 cylinder, keeping it Ca. smogable, and adding HP? What are Tranny considerations I must pay attention to? Left turn signal is rapid, Looked into replacing bulb, and found it impossible to remove. Just can't get to it. Thanks. Also, need a 97 SE alloy wheel. Where can I find one? Link to comment Share on other sites More sharing options...
Velocifero Posted August 13, 2007 Share Posted August 13, 2007 What are my options to rebuild/replace my stock 97 accord 4 cylinder, keeping it Ca. smogable, and adding HP?What are Tranny considerations I must pay attention to? Left turn signal is rapid, Looked into replacing bulb, and found it impossible to remove. Just can't get to it. Thanks. Also, need a 97 SE alloy wheel. Where can I find one? motor swapping maybe? h22 or f20b are good ones. which bulb is out exactly? Link to comment Share on other sites More sharing options...
Pnizz Posted August 14, 2007 Author Share Posted August 14, 2007 motor swapping maybe? h22 or f20b are good ones. which bulb is out exactly? h22 and f20b? hotter motors? like from vtec? bulb out is front right marker (turn) signal. I removed the air box and tube. still could not get to the back of the lens. thanks Link to comment Share on other sites More sharing options...
James Matteu Posted August 14, 2007 Share Posted August 14, 2007 Velocifero: "youre gonna need a long crosstip screwdriver and maybe a flashlight. theres a little hole next to each bumper lens on the inside of the bottom opening on the bumper. shine a flashlight in there and look for a screw. unscrew that and gentle pull towards the middle of the car (middle meaning between the headlights). you might have to stick your hand behind and persuade it a bit, but it should pop out. installation is reverse of removal. dont forget to put the tab-side in first though, then the other side and screw it in." I could not have said it better myself. 15 Link to comment Share on other sites More sharing options...
