vasu Posted August 29, 2007 Share Posted August 29, 2007 HI , I have 2001 honda accord 4 cylinder 4 dr 2.3L. It has around 92k miles. From the 5 to 6 months, I am observing engine has a little shake(Vibration) when I start. Also some noise from under the car near rear wheels. I did 90k service myself, I changed spark plugs( NGK - Iridium), air filter,oil , oil filter, checked all the fluid level, radiator flush. Recently I changed water pump. Timing belt is good so far. I did not changed distributor rotor and cap. I am not sure whats the problem. Even after above 90k service, the engine vibration or shaking doesn't gone away, I will check distributor rotor. I am curious does any have the same or similar problem ? if yes what should I do ? Thanks Vasu Link to comment Share on other sites More sharing options...
CleanGSR Posted August 29, 2007 Share Posted August 29, 2007 First thing to come to my mind is checking your motor mounts. It's not uncommon for one to go bad around 100k and a bad one would definately cause some extra vibrations. Link to comment Share on other sites More sharing options...
vasu Posted August 29, 2007 Author Share Posted August 29, 2007 I did changed the motor mounts 6 months ago. It did not helped. Also when it starts little shaking, I notice there is a loss of power also. Link to comment Share on other sites More sharing options...
Jedikid Posted September 3, 2007 Share Posted September 3, 2007 a/c??? that's what my civic did. overcharged. once i released the pressure it stopped shaking. Link to comment Share on other sites More sharing options...
