atomiclightbulb Posted September 9, 2007 Share Posted September 9, 2007 1995 Accord LX, 4 Cyl/2.2L I was driving home late this morning under fairly hot conditions (88F/31C) and I got stuck behind a lot of cars waiting for a red light. There were so many cars that I wasn't able to get past the intersection at the next green light. While waiting for the light to turn green again, I noticed that the temp gauge started climbing past the middle mark, and then about 5-10 seconds before the light turned green, it started going into the red zone. I drove through the intersection slowly and looked for a safe place to pull over to let my car cool down, but I noticed that as I continued to drive, the temperature gauge started falling. I was going about 30-35 MPH through local neighborhoods, and eventually the temp gauge fell to about the midline. I got home and let the Accord cool down for about 30 mins while I ate lunch, and then I went to check the coolant levels. - Radiator reserve tank was almost dry. The manual said to add coolant to the tank, so I did. - I then checked the radiator level. The coolant appeared low here as well, so I added coolant up the the base of the filler neck as the manual suggested. Later that day, I drove the car about 2 miles. When I returned home, I saw drops (not a whole lot, but enough to get my attention) of liquid on the driveway where my car had been parked. I used a paper towel to dab up some of the liquid and it appears to be coolant from my car :( I've run the car at idle again to check on a few things. - The two fans in the front by the radiator work. I turned on the AC and they both start spinning. - I reved the engine to 2500RPM for about 30 seconds and the temp stays well below the middle mark. - I checked the coolant levels again. The reserve tank appears fine, but the radiator coolant level has again fallen below the base of the filler neck. - No unusual noises from the engine. Oil level and other liquids are fine. Exhaust is normal. Any ideas on what (if anything) might be wrong? I think I might have a coolant leak somewhere. One other thing to note: I've noticed that when I park the car and turn off the engine, the front fans will sometimes turn on for about 2 mins. I figure this might be relevant because the fans move air over the radiator. Thanks in advance. Link to comment Share on other sites More sharing options...
Kegger Posted September 9, 2007 Share Posted September 9, 2007 Sounds like you gotta leak there. Check all your hoses and your radiator. If somethings bad, replace it. Link to comment Share on other sites More sharing options...
