rwhite1102 Posted September 17, 2007 Share Posted September 17, 2007 I purchased my first honda 96 4 cylinder accord with 82k and the clutch needs replacing. I would like to do the work myself and am wonder how challanging this work will be. I am also looking for clutch componant recommendations. I am looking for reliability and durability. Thanks, Bob Link to comment Share on other sites More sharing options...
James Matteu Posted September 17, 2007 Share Posted September 17, 2007 Tip 1: Get a Clutch pack kit (Clutch, throw bearing, alignment dowel, and pressure plate) Tip 2: Go to NAPA, it's the closest you'll get to buying from the Honda Dealership Tip 3: Have either a) a lift or b) a 2-ton jack and rampstands. For every 6 inches off the ground you get between 0-60 inches, the job becomes 10% easier. I had never done it before, I did it by myself, and only had the Honda Service Manual to guide me. I counted upward of 80 discrete steps in removing the clutch, so roughly 160 total steps to complete the job. I spend around 20 hours the first time, but if I had to do it again it would take me 4-5 hours by myself. To my credit, up to that point in time I had a good bit of mechanical experience. I had: adjusted valves, changed oil, changed brake pads, changed CV axles, changed valve cover gaskets, installed a new master cylinder, and dabbled with the stereo system. I messed up in keeping track of how many bolts I had removed from the transmission, so I wasted some time pulling on a transmission that had one bolt holding to the engine (hidden under the distributor). I messed up by not bolting the transmission back to the engine right away after day 1 and spent day 2 wondering how everything came out of alighnment. After completing a job this big, I had the confidence to tackle anything that has come my way. Have fun! I did! Link to comment Share on other sites More sharing options...
