honda91chris Posted October 30, 2007 Share Posted October 30, 2007 When i'm driving at 120km/h there's a smell of burning oil coming in the car from the vent. What could cause that? I'm pretty sure that it's a leak some where but where? Link to comment Share on other sites More sharing options...
Hatch92 Posted October 31, 2007 Share Posted October 31, 2007 whats 120km/h in MPH? Link to comment Share on other sites More sharing options...
airjordan223 Posted October 31, 2007 Share Posted October 31, 2007 about 75 mph Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2007 Share Posted October 31, 2007 im guessing your oil pan leaking in the rear onto the exhaust. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 31, 2007 Share Posted October 31, 2007 i'm with cranny on this one. Link to comment Share on other sites More sharing options...
AccordHEART Posted October 31, 2007 Share Posted October 31, 2007 It's a Honda. You know it's healthy if you're burning a quart a day. XD Link to comment Share on other sites More sharing options...
xer0 Posted November 1, 2007 Share Posted November 1, 2007 It's a Honda. You know it's healthy if you're burning a quart a day. XD good then my car is " A OK " Link to comment Share on other sites More sharing options...
honda91chris Posted November 1, 2007 Author Share Posted November 1, 2007 So...replace the oil pan? Link to comment Share on other sites More sharing options...
Kastigir Posted November 1, 2007 Share Posted November 1, 2007 So...replace the oil pan? Just the gasket most likely. Link to comment Share on other sites More sharing options...
StockHonda91 Posted April 27, 2008 Share Posted April 27, 2008 When i'm driving at 120km/h there's a smell of burning oil coming in the car from the vent. What could cause that? I'm pretty sure that it's a leak some where but where? How many miles on this engine? If you have high mileage on the engine, the rings may be worn enough to produce blowby that is forcing engine oil through the PCV valve and into the intake. 4/27/2008: Follow-up If what I suggested above is true, you'll be able to tell by pulling the PCV hose off the intake manifold. If it is wet with oil, your engine is probably doing as described. One partial cure is to put a small orifice (1/16" hole) inside the hose leading to the manifold thereby reducing the amount of area that the blowby can pressure the oil out of the engine and into the intake manifold. Note: If the blowby is bad enough it will find another path through the breather hose connection upstream of the throttle body. The orifice in the PCV hose should reduce though probably not totally stop the oil usage. Link to comment Share on other sites More sharing options...
Tubbith Posted April 27, 2008 Share Posted April 27, 2008 Bring it back from the dead....Oct. 31, 2007.... Link to comment Share on other sites More sharing options...
brokenbones Posted May 2, 2008 Share Posted May 2, 2008 When i'm driving at 120km/h there's a smell of burning oil coming in the car from the vent. What could cause that? I'm pretty sure that it's a leak some where but where? my 97 accord used to leak oil and it was because my step dad changed the oil himself and tightened the filter too much and after a while the seal got compressed and it sprayed oil all over under my car and on the muffler and you could smell it every where. Link to comment Share on other sites More sharing options...
Hatch92 Posted May 2, 2008 Share Posted May 2, 2008 brought back from the dead twice now Link to comment Share on other sites More sharing options...
