ducttape2334 Posted December 17, 2007 Share Posted December 17, 2007 i want to get a nice amp to power my speakers in the del sol. so i would need a four channel. my speakers can handle 50 watts RMS and a peak of 130 (i think). my question is would i need to get an amp that outputs 50 RMS per channel at 4 or 2 ohm. i still have not figured out ohm stuff. any help thanks if anyone has any recommendations i would appreciated it...trying not to spend more then $250 on this Thanks Link to comment Share on other sites More sharing options...
elianthony Posted December 20, 2007 Share Posted December 20, 2007 i want to get a nice amp to power my speakers in the del sol. so i would need a four channel. my speakers can handle 50 watts RMS and a peak of 130 (i think). my question is would i need to get an amp that outputs 50 RMS per channel at 4 or 2 ohm. i still have not figured out ohm stuff. any help thanks if anyone has any recommendations i would appreciated it...trying not to spend more then $250 on this Thanks You should be fine with an amp that puts out between 35 - 50 watts RMS per channel @ 4 ohms. 4 ohms is what most full-range car speakers are rated at, when you get into subs you can get them in either 2, 4, or 8 ohm configurations. Most car amps run out of the box at 4 ohms, some are capable of of running down to 2, 1, 1/4, or 1/8 ohm loads, which will pull more power out of amp and make them run hotter. I've been out of the install game for a while so I couldn't suggest what to buy nowadays, but as far as amps go I ran Phoenix Gold, MTX, and Alpine 4-channel amps without problems. Link to comment Share on other sites More sharing options...
Repsol Posted December 25, 2007 Share Posted December 25, 2007 What kind of speakers do you have? The two door speakers I have Blaupunkt, and for the rear, I have Polk Audio. Link to comment Share on other sites More sharing options...
ducttape2334 Posted December 26, 2007 Author Share Posted December 26, 2007 http://www.eclipse-web.com/integrated/se8365.html those are the ones i have. after i get my header and exhaust finished i am switching everything audio to pioneers premier brand. I had them before and they are amazing just expensive Link to comment Share on other sites More sharing options...
